rolly850R Posted June 3, 2005 Report Share Posted June 3, 2005 I'm looking at replacing the front spring seats and while I'm under there, I am considering replaing the springs and shocks.My calcluations have it that the H+Rs will lower the car by about 10mm up front and 5mm rear, based on R springs being 20mm lower than standard.Can anyone confirm this, and if you are running 215/45 17's do you get any rubbing.Shocks will probably be koni, either yellow or the new FSD's.oh FYI spring seats in NZ are $91USD EACH. Only available from Volvo dealer <_< Link to comment Share on other sites More sharing options...
Veneficus Posted June 3, 2005 Report Share Posted June 3, 2005 I rub with that tire size but only because I have a wider offset than most. Link to comment Share on other sites More sharing options...
rolly850R Posted June 3, 2005 Author Report Share Posted June 3, 2005 Can anyone confirm that I will get my calculated drop with the H+R's?The right front sits 8mm lower than the left (assuming a stuffed spring seat 'caus it blimmin noisy!) and that looks quite nice for a ride hight.I would go straight to KW's but i think they would be too harsh for a daily driver here.ThanksSimon Link to comment Share on other sites More sharing options...
orange850t Posted June 4, 2005 Report Share Posted June 4, 2005 My guess is that KW's would be a better option for comfort at LOW height settings. Don't get me wrong I luv my H&R's, not sure the actual measurements but I can get one finger between fender lip and tire on my fronts with 205/55/16's and 2 or so on the rear. Real scientific eh....YMMV Link to comment Share on other sites More sharing options...
rolly850R Posted June 7, 2005 Author Report Share Posted June 7, 2005 Thanks for the input guys,I just ordered the spring seats from fcpgroton <sp?> and they will be landed in NZ with all the required nuts and bolts for the price of 1 spring seat from the NZ dealer!!!!!I will probably get the KW v3 eventually - based on the current suspension threads going on. - be very interested to see what the koni/HR combo is like compaired to the weitecs <sp?>. Link to comment Share on other sites More sharing options...
