Zulu Posted June 6, 2005 Report Share Posted June 6, 2005 What is the tensel strength and yield of stock connecting rods? Has anyone cryo-treated or shotpillened the stock rods as opposed to buying aftermarket ones? Link to comment Share on other sites More sharing options...
JHEIII874T5M Posted June 6, 2005 Report Share Posted June 6, 2005 weak sauce Link to comment Share on other sites More sharing options...
Swedish Mike Posted June 6, 2005 Report Share Posted June 6, 2005 What is the tensel strength and yield of stock connecting rods? Has anyone cryo-treated or shotpillened the stock rods as opposed to buying aftermarket ones?←When you open up the engine it will cost you a load of money, bearings, sealings, gaskets and work.I would never do all this and use the stock rods, you can make them a little stronger if you cryo or shot them but not worth the trouble in our engines.The stock pistons are good but the rods are bad.../Mike Link to comment Share on other sites More sharing options...
Guest DougK Posted June 6, 2005 Report Share Posted June 6, 2005 shotpeening rods would be worth maybe 10% more strength. Not much. Link to comment Share on other sites More sharing options...
volflo Posted June 6, 2005 Report Share Posted June 6, 2005 The stock pistons are good but the rods are bad.../Mike←having said this, mike, what aftermkarket rods would work with stock pistons?I would be looking for a solution where you simply exchange the oem rods for stronger ones and keep all the rest. is that feasible? Link to comment Share on other sites More sharing options...
theunderlord Posted June 6, 2005 Report Share Posted June 6, 2005 shotpeening rods would be worth maybe 10% more strength. Not much.←Really? that much you think? hmm.... I'm with Mike... if you took the time to rip open your engine.. you best be replacing things with Aftermarket parts. Link to comment Share on other sites More sharing options...
Swedish Mike Posted June 6, 2005 Report Share Posted June 6, 2005 having said this, mike, what aftermkarket rods would work with stock pistons?I would be looking for a solution where you simply exchange the oem rods for stronger ones and keep all the rest. is that feasible?←I use my own MK-R rods or Verdi, both got stock size and can be used to OEM or forged pistons.The Verdi´s is a bit stronger, maybe 200 Nm. My rods are tested to 700 Nm without a problem.Simple as that!/Mike Link to comment Share on other sites More sharing options...
EricF Posted June 6, 2005 Report Share Posted June 6, 2005 You can probably get SPM rods shipped to your door for not much more than shot-peening or cryo-treating stock rods... And they would be tons stronger.Like Mike said, it's a lot of money to take the block apart to get to them and to put it back together. If you're on that kind of budget and have that kind of time, do it the right way. Link to comment Share on other sites More sharing options...
volflo Posted June 7, 2005 Report Share Posted June 7, 2005 what would be a suitable verdi rod source? bearings incl.?thanks. Link to comment Share on other sites More sharing options...
Zulu Posted June 7, 2005 Author Report Share Posted June 7, 2005 Someone link me to SPM rods please. Link to comment Share on other sites More sharing options...
