dcintraining Posted June 30, 2005 Report Share Posted June 30, 2005 Hi All,My buddy has an 93 850GLT that had an exhaust leak which he fixed. The car ran poorly when he had the leak and his check engine light came on. The computer is showing Code 113 (A2): Short Term fuel mixture too rich. The car is also idling poorly, almost stalls at stops then revs slightly.How do I reset this code so the check engine light will turn off. I can't seem to find directions on how to reset the codes. Any other ideas? Possibly a vacuum leak?Thanks for all your assistance!Eoin Link to comment Share on other sites More sharing options...
WhiteT5 Posted June 30, 2005 Report Share Posted June 30, 2005 http://www.volvospeed.com/CheckEngine.phpSounds like a leaky vacuum line and/or dirty idle air control valve. Link to comment Share on other sites More sharing options...
Guest Guest Posted June 30, 2005 Report Share Posted June 30, 2005 Thanks for the help, we reset the codes, apparently there was more than just the 113. All the other codes are related to mixture. I'll check all the vacuum hoses to make sure there is no leak.Thanks again. Link to comment Share on other sites More sharing options...
