uscgc70 Posted July 5, 2005 Report Share Posted July 5, 2005 When i start my car my recirc. and a/c off buttons blink for a few seconds then go off. in the manual it says this means something is wrong, but when i hook it up to a code reader i don't get any codes for hvac. could someone point me in the right direction please Link to comment Share on other sites More sharing options...
merlin390 Posted July 5, 2005 Report Share Posted July 5, 2005 Please open your phone book to the automotive section and look for your nearest Volvo dealer or Volvo Indy Tech and make an appointment. You can not access HVAC, TRACS, SRS, Tranny etc codes with the hand held scanner Link to comment Share on other sites More sharing options...
highspeed11 Posted July 13, 2005 Report Share Posted July 13, 2005 As long as your fan(A/C, Heater)works you will be ok. It's almost likely your cabin temp sensor is either clogged or otherwise faulty. You could replace it but would need to erase the code anyways. Take it to the dealer and see what they say. Good luck. Link to comment Share on other sites More sharing options...
s40euro Posted July 13, 2005 Report Share Posted July 13, 2005 As long as your fan(A/C, Heater)works you will be ok. It's almost likely your cabin temp sensor is either clogged or otherwise faulty. You could replace it but would need to erase the code anyways. Take it to the dealer and see what they say. Good luck.←Or bad electrical part of the ignition switch Link to comment Share on other sites More sharing options...
Zappo Posted July 13, 2005 Report Share Posted July 13, 2005 As long as your fan(A/C, Heater)works you will be ok. It's almost likely your cabin temp sensor is either clogged or otherwise faulty. You could replace it but would need to erase the code anyways. Take it to the dealer and see what they say. Good luck.←I probably have a bad temp sensor in my car. I do get the blinking every once in a while, but it isn't every time. Recently I have had a hard time keeping the tempature in the car steady. Link to comment Share on other sites More sharing options...
BtownVolvo Posted July 13, 2005 Report Share Posted July 13, 2005 Funny, I just replaced my A/C and its doin' that to me also! :angry: Link to comment Share on other sites More sharing options...
550 Posted July 13, 2005 Report Share Posted July 13, 2005 hmm, it will blink if you have a bad ignition switch? Link to comment Share on other sites More sharing options...
EMDII Posted July 13, 2005 Report Share Posted July 13, 2005 "If a fault occurs (indicated by flashing of the "REC" and "AC OFF" warning lights onthe control panel, the on=board diagnostics can be used to initiallypinpoint any problem areas without the use of special test equipment. Once this has been done, further tests may be necessary to determine the exact nature of the fault; whether a component itself has failed, or whether it is a wiring or other inter-related problem"Short version: need a scan tool. There are over 40 codes, and the dealer can most likely do it quickly. Then you can chose what repair, if any, to pursue. There are four t-sensors inside: driver's, driver's duct, passenger's, and passenger's duct (if you have the ECU automatic climate control).you could also have a slow damper that cycles and clears the fault code. Moral of the story: only a scan will tell, and it has to be done right. Link to comment Share on other sites More sharing options...
MrWinkey Posted July 14, 2005 Report Share Posted July 14, 2005 Agreed you need to have the codes read and go from there...the lights are blinking because it has detected a fault Link to comment Share on other sites More sharing options...
BtownVolvo Posted July 26, 2005 Report Share Posted July 26, 2005 Went to the dealer today and found out what all the hoop-la was about. Got it scanned (free haha) and these are the results...Code: ECC 414-Cabin temperature fan faulty. P/N: 3524841 $75.34 at myswedishpartsCode: ECC 433-Blower motor possibly faulty.Service lady told me that it was probably the temp sensor. But my A/C works fine so I'm not too worried.Hope this clears this up.-Reid Link to comment Share on other sites More sharing options...
