Guest Guest_jp764ti Posted April 20, 2004 Report Share Posted April 20, 2004 hey where should i hook up the 12v "power on" lead from? i saw on that project 850 websight that he did it off of his power antena but mine is a waggon with the antena in the glass.... so can i still do it off of there or do i need to run it all the way up to the wire bundel behind the radio and if so which wire do i need to tap into?thanksjp Link to comment Share on other sites More sharing options...
nagrod18 Posted April 20, 2004 Report Share Posted April 20, 2004 if you are talking about the wire that turns on the amp I believe it is also called a remote wire. There was a wire with "remote" written on it on my aftermarket head unit wiring harness. Link to comment Share on other sites More sharing options...
Guest Guest Posted April 21, 2004 Report Share Posted April 21, 2004 im doing it on a stock headunit and i figgured it out allready thanks thoughps. i made a kill switch out of an old 740 antena switch so i can go from loud to L O U D and it fits in the slot allmost perfectlyjp Link to comment Share on other sites More sharing options...
Serge Posted April 21, 2004 Report Share Posted April 21, 2004 if you are talking about the wire that turns on the amp I believe it is also called a remote wire. There was a wire with "remote" written on it on my aftermarket head unit wiring harness.850s have an external amp? Link to comment Share on other sites More sharing options...
AnthonyR Posted April 22, 2004 Report Share Posted April 22, 2004 850s have an external amp? It's rare, and almost always in R's. I have yet to hear about one being in a T5 or lower.As far as that writeup I did on my site, you probably won't be able to do it that way unless you can find the power module for your glassmount antenna (It should be powered) That or you can use the power antenna wire behind the deck or better yet the Accessory power wireHere's a diagramBasically you can tap into 13A - Yellow/Purple stripe for the ACC wire (recommended) or the antenna wire 3A - Blue/White stripe.All this info can be found herehttp://volvospeed.com/Repair/radiocon.htm Link to comment Share on other sites More sharing options...
