own6volvos Posted July 20, 2005 Report Share Posted July 20, 2005 I am trying to figure out if the front sensor on our 2001 v70 is screwed, but coming into problems actually testing it. Its a 4 wire sensor, where the ground for the sensor is supplied from the wires instead of the exhaust (or so I think). This leave 2 black wires for the heater, and then one grey wire and one blue wire. Now hooking up a multimeter to these the thing will first screw with my autorange in the low settings, then just stop working and not do anything be the time i switch it up to a higher voltage range.This brings me to the 2nd question, do the newer Volvos use standard o2 sensors, or are they some wacky resistive style units? I have seen some 4 wire universal ones up on ebay for this same make and model, which leads me to believe they are the same.All of this is to trace back why the emmisions service crap comes on every other day, and sometimes just turns off completely. The dealer keeps telling us that whenever they scan it, nothing shows up, and it seems to always come up when not at the dealer. With a standard obd2 scanner it pulls up the P420 or cat fault, but a wacky o2 sensor could also mkae that go. Its gas mileage went from 30-32 down to 26 which also points to the o2 sensor. Since we aren't really a money tree, throwing cash at items that may or may not be the issue isn't really an option unless they are cheap parts. I have a few brand new 4 wire normal style o2 sensors laying around, but have been worried about screwing up the car because it took some wacky resistive unit or custom WB thing.To add to the wackyness, here is the Vadius tidbits on thisFront Sensor:The measurement range 0-2. The normal value is λ=1. When the fuel air mixture is rich λ<1. When the fuel air mixture is lean λ>1.#A24(#A24)Signal (+)Front heated oxygen sensor (HO2S) signal (+)-λ= 0.95 V>700 mVλ= 1.10 V<200 mV#A41(#A41)Signal (–)Front λheated oxygen sensor (HO2S)-λ= 1 when the current is approximately +0.2 mANegative current when the fuel air mixture is rich. Range: [-12 mA, +12 mA]#A42(#A42)Signal (+)Front λheated oxygen sensor (HO2S)-λ= 1 when the current is approximately +0.2 mAPositive current when the fuel air mixture is lean Range: [-12 mA, +12 mA]Rear sensor:Measurement range 0-5 V. Operating range 0-1 V. The normal value when the engine is running under an even load is ≈ 0.6 V.Anyone care to translate that? Link to comment Share on other sites More sharing options...
merlin390 Posted July 20, 2005 Report Share Posted July 20, 2005 they use a bosch 4 wire O2 Sensor.go to the bosch home page and poke around some Link to comment Share on other sites More sharing options...
Guest Guest Posted July 20, 2005 Report Share Posted July 20, 2005 Well, there seems to be a few different styles of 4 wire sensors that Bosch makes. Also, under the vehicle part finder thing, there is no section for o2 sensor for a 2001 v70 n/a Link to comment Share on other sites More sharing options...
own6volvos Posted July 20, 2005 Author Report Share Posted July 20, 2005 Me^^^ Link to comment Share on other sites More sharing options...
starfish Posted July 21, 2005 Report Share Posted July 21, 2005 That symbol is the lower-case Greek letter lambda. The Swedes got fancy here and used it to describe stoichiometric air to fuel ratio. A lamda sond is the oxygen sensor. I'm not 100% sure what exactly you are trying to state about your problem but to me it seems like you have a catalyst efficiency failure code. Many times this is not caused by a bad O2, but blown out exhaust manifold gaskets. Link to comment Share on other sites More sharing options...
own6volvos Posted July 22, 2005 Author Report Share Posted July 22, 2005 That symbol is the lower-case Greek letter lambda. The Swedes got fancy here and used it to describe stoichiometric air to fuel ratio. A lamda sond is the oxygen sensor. I'm not 100% sure what exactly you are trying to state about your problem but to me it seems like you have a catalyst efficiency failure code. Many times this is not caused by a bad O2, but blown out exhaust manifold gaskets.←Its more of a "this problem won't go away", but how do I fix it without buying brand new dealer parts.I am curious if a standard 4 wire sensor similar to what the 850's use, and lots of other cars will work spliced in. Link to comment Share on other sites More sharing options...
Bay13 Posted July 23, 2005 Report Share Posted July 23, 2005 http://www.fcpgroton.comget the OEM O2 sensors, I've not seen many positive results with the shop around and jury rig method. Link to comment Share on other sites More sharing options...
