Newbie Posted July 24, 2005 Report Share Posted July 24, 2005 I have removed the stock radio w/ ease.then I try to push the climate control out from the back w/ out luck.Seems something is screw in or clip locked the unit?Can someone show me how to do so, please.I am trying to change the dead bulb inside.When I remove the knob I can see the bulb, but I can't do anything about it.thanks~Edit: 96 850GLT Automatic Climate control Link to comment Share on other sites More sharing options...
Veneficus Posted July 24, 2005 Report Share Posted July 24, 2005 First what model are you working with and do you have a manual or automatic temp control. Since you can't push it out from the back I'm betting its a manual. Here is how to remove a manual. First take off the 3 knobs and then remove the faceplate by removing the 3 phillips screws. Carefully take off the faceplate and then you should have full access to the bulbs. :D Link to comment Share on other sites More sharing options...
Newbie Posted July 24, 2005 Author Report Share Posted July 24, 2005 First what model are you working with and do you have a manual or automatic temp control. Since you can't push it out from the back I'm betting its a manual. Here is how to remove a manual. First take off the 3 knobs and then remove the faceplate by removing the 3 phillips screws. Carefully take off the faceplate and then you should have full access to the bulbs. ←sorry forgot to mention.96 850GLT w/ Dual Automatic.And when I remove 3 knob, there is NO screws of anything.Thanks, Link to comment Share on other sites More sharing options...
Veneficus Posted July 24, 2005 Report Share Posted July 24, 2005 :/If I had an auto climate I could help ya. Link to comment Share on other sites More sharing options...
Newbie Posted July 24, 2005 Author Report Share Posted July 24, 2005 :/If I had an auto climate I could help ya.←no problem thanks for your reply.I hope someone here know how also... Link to comment Share on other sites More sharing options...
Serge Posted July 24, 2005 Report Share Posted July 24, 2005 Take out the radio and rest it on the shift knob. Stick your hands behind the climate control and push it out. It'll come right out. Link to comment Share on other sites More sharing options...
Newbie Posted July 24, 2005 Author Report Share Posted July 24, 2005 Take out the radio and rest it on the shift knob. Stick your hands behind the climate control and push it out. It'll come right out.←I swear I tried to push it out so hard w/ my both hand, it wouldn't even move. all I see is my entire center console is about to torn apart. Link to comment Share on other sites More sharing options...
Serge Posted July 24, 2005 Report Share Posted July 24, 2005 There is really no other way I believe. Rock it from side to side a bit. Link to comment Share on other sites More sharing options...
Newbie Posted July 24, 2005 Author Report Share Posted July 24, 2005 There is really no other way I believe. Rock it from side to side a bit.←I did! I am so fraustrated. I can kind of rock it on vertical direction just not side to side. Link to comment Share on other sites More sharing options...
Serge Posted July 24, 2005 Report Share Posted July 24, 2005 That's quite odd. What I did was push with one hand and keep my other hand on the face of the climate control. This way I didn't have to worry about it popping out into uncontrollably. Link to comment Share on other sites More sharing options...
Newbie Posted July 24, 2005 Author Report Share Posted July 24, 2005 That's quite odd. What I did was push with one hand and keep my other hand on the face of the climate control. This way I didn't have to worry about it popping out into uncontrollably.←when you pop it out, did you see any sign of side clip or anything?I check the photo from ebay and it seems the unit has bigger face but slimmer body. (what I thought is..if it isn't clip lock, wouldn't it just fall off?) Link to comment Share on other sites More sharing options...
Newbie Posted July 24, 2005 Author Report Share Posted July 24, 2005 anyone? Link to comment Share on other sites More sharing options...
850drag Posted July 24, 2005 Report Share Posted July 24, 2005 did you check already disconnect the wiring front the rear of the unit? do you have a thin puddy knift? if you do try taking the knift and sliding it between the unit and the dashslide it all around the face of the unit, this will tell you if its caught on something. good luck Link to comment Share on other sites More sharing options...
