montgom Posted July 26, 2005 Report Share Posted July 26, 2005 In my 2003 S60 with an Automatic trans and 2.4 liter motor, what fluid do I use in my power steering? DEXRON III?I assume changing it is a good idea? Bob :unsure: Link to comment Share on other sites More sharing options...
Bay13 Posted July 27, 2005 Report Share Posted July 27, 2005 Actually from 1999 to present Volvo has switched over to a clear/green synthetic power steering fluid. I'd stick with that, it handles the foaming that can happen a lot better than putting in dexron III. Link to comment Share on other sites More sharing options...
montgom Posted July 27, 2005 Author Report Share Posted July 27, 2005 Actually from 1999 to present Volvo has switched over to a clear/green synthetic power steering fluid. I'd stick with that, it handles the foaming that can happen a lot better than putting in dexron III.←Thanks (again) for the information. Is there a non-Volvo equivalent of this clear/green syntheitc fluid? :) Link to comment Share on other sites More sharing options...
Bay13 Posted July 27, 2005 Report Share Posted July 27, 2005 At one of the other dealers I worked at they did VWs as well and I noticed their fluid was clear/green and synthetic as well. So it's not just a Volvo thing. I'd check with your local auto stores and ask for Synthetic power steering fluid and see what they can come up with. Link to comment Share on other sites More sharing options...
V Tuning 850 Posted July 28, 2005 Report Share Posted July 28, 2005 I am pretty sure mine is red in color. When it was foaming sometime ago it looked red. Link to comment Share on other sites More sharing options...
montgom Posted July 28, 2005 Author Report Share Posted July 28, 2005 At one of the other dealers I worked at they did VWs as well and I noticed their fluid was clear/green and synthetic as well. So it's not just a Volvo thing. I'd check with your local auto stores and ask for Synthetic power steering fluid and see what they can come up with.←I will do just that this weekend. Thanks for the idea.Bob Link to comment Share on other sites More sharing options...
highspeed11 Posted July 28, 2005 Report Share Posted July 28, 2005 I am pretty sure mine is red in color. When it was foaming sometime ago it looked red.←It can become a reddish-brown when it gets old. Either that, or it's ATF. Link to comment Share on other sites More sharing options...
montgom Posted July 29, 2005 Author Report Share Posted July 29, 2005 At one of the other dealers I worked at they did VWs as well and I noticed their fluid was clear/green and synthetic as well. So it's not just a Volvo thing. I'd check with your local auto stores and ask for Synthetic power steering fluid and see what they can come up with.←Wow, this stuff is expensive from Volvo! Quoted something like 19 dollars for 1/2 or 1 liter bottle.WOW! Link to comment Share on other sites More sharing options...
montgom Posted July 30, 2005 Author Report Share Posted July 30, 2005 Actually from 1999 to present Volvo has switched over to a clear/green synthetic power steering fluid. I'd stick with that, it handles the foaming that can happen a lot better than putting in dexron III.←I looked at the dipstick for my automatic transmission on my 2003 S60, non-turbo 2.4l. It said special ATF and then said look in the owmers manual. The owners manual just said ATF (not very helpful )So, per what I have learned here (in other threads), my dipstick is about 9 inches long ( 8 1/2 inches actually) Now, my shifter is P R N D 4 3 L (yes, there is no 2!!!).I am guessing three things here1) My tranny takes synthetic ATF and that synthetic tranny fluid can come from Volvo or I can use Mobil 1 synthetic Tranny fluid (which is 3309 spec) (also, Mobil apparently makes the syntetic ATF for Volvo).2) If the owners manual says to use ATF fluid in the power steering, what they mean is use synthetic tranny fluid (either Volvo ATF synthetic or Mobil 1 synthetic tranny fluid). 3) Do not use Dexron III in either the transmission or for the powering steering. BobPS Corrections, clarifications or any thing else welcomed. PSS I went to the Volvo dealer and they sold me a synthetic power steering fluid. They were "unfriendly" when I tried to buy some Volvo ATF fluid since they made it clear that it never needed to be changed. I remained calm, polite and just left with my synthetic power (Volvo brand ) steering fluid. Link to comment Share on other sites More sharing options...
Bay13 Posted July 30, 2005 Report Share Posted July 30, 2005 Just one comment, Mobil 1 makes volvos synthetic transmission fluid to specs 3309. All mobil 1 synthetic transmission fluid is not 3309 specs. So when you say you can put Mobil 1 synthetic transmission fluid in your car you are correct only if it's the mobil 1 3309 specs fluid. Link to comment Share on other sites More sharing options...
BillAileo Posted July 30, 2005 Report Share Posted July 30, 2005 If the online version of your car's owner's manual is accurate, it confirms on page 148 that the fluid for your automatic transmission is "Automatic: Volvo transmission oil 1161540-8" which is Mobil 3309.The same page addresses the fluid required for your power steering as simply "ATF". I do not believe your power steering system is anywhere near as particular about the ATF used as your transmission is. However, it is probably a good idea not to mix fluids.Bottom line: do not use Dexron III in your transmission but you could probably use it as the power steering fluid.Bill Link to comment Share on other sites More sharing options...
montgom Posted July 30, 2005 Author Report Share Posted July 30, 2005 Just one comment, Mobil 1 makes volvos synthetic transmission fluid to specs 3309. All mobil 1 synthetic transmission fluid is not 3309 specs. So when you say you can put Mobil 1 synthetic transmission fluid in your car you are correct only if it's the mobil 1 3309 specs fluid.←Yes, the Mobil 1 synthetic ATF is not Mobil 3309 Boy, am I glad that I ask and do not assume! I am now looking for a source of Mobil 3309. Anyone know?Bob Link to comment Share on other sites More sharing options...
BillAileo Posted July 31, 2005 Report Share Posted July 31, 2005 I located a regional Mobil lubricants distributor through the followiong website and buy by the case:http://www.prod.exxonmobil.com/channelpart...r_directory.jspBill Link to comment Share on other sites More sharing options...
montgom Posted July 31, 2005 Author Report Share Posted July 31, 2005 I located a regional Mobil lubricants distributor through the followiong website and buy by the case:http://www.prod.exxonmobil.com/channelpart...r_directory.jspBill←Thanks! Any experience with them willing to sell by the case?Bob Link to comment Share on other sites More sharing options...
BillAileo Posted July 31, 2005 Report Share Posted July 31, 2005 The distributor for northeastern Pennsylvania where I live was happy to sell it to me that way at about $43 for a case. A case was just about right when I changed the fluid in the '03 XC70. Bill Link to comment Share on other sites More sharing options...
