Guest Guest Posted August 30, 2005 Report Share Posted August 30, 2005 these guys list the HOLLY NOS system as S80 compatible.http://www.seffects.com/parts/NOS05130.htmInstructions for Part# 05130NOShttp://www.holley.com/TechService/Instructions.aspsomeone in the thread said that any EFI system should work. doesn't look like a problem to me to do it this way; except i don't know what effect the dual turbo's will have on feeding the WET NOS fuel injection. My mechanic only has experience with throttle body injection kits, and he doesn't know of any one made for the S80/T6 yet. he's concerned with equal fuel/NOS mixture per cylinder, which you'd expect would be critical, but this EFI way seems to do the mixture upstream enough. i'm no expert (of course!) I'll have to wait on Rob's report, or my mechanics investigations.for the moment though, the ECU kit is awesome! will be adding Bilstein Shocks and ipd anti-sway bars (22-25mm) next week! Link to comment Share on other sites More sharing options...
Guest Guest Posted August 30, 2005 Report Share Posted August 30, 2005 oops! that was me. i didn't know you could post without logging in :) Link to comment Share on other sites More sharing options...
the underlørd Posted August 30, 2005 Report Share Posted August 30, 2005 oops! that was me. i didn't know you could post without logging in ←you did it again.. :) Link to comment Share on other sites More sharing options...
Guest Guest Posted August 30, 2005 Report Share Posted August 30, 2005 geez i'm stupid - it's skywriter Link to comment Share on other sites More sharing options...
PorBleemo Posted August 31, 2005 Report Share Posted August 31, 2005 geez i'm stupid - it's skywriter←I do that all the time to. They should disable that. :) Link to comment Share on other sites More sharing options...
SkyWriter Posted September 1, 2005 Author Report Share Posted September 1, 2005 I will have a full write up for the Nx system in the next week or two. I will be testing 35,50,75 hp shots.The wet system would be the best to go unless you have a system where you can increase the injector duty when nitrous is activated. Look to gain 100hp on nitrous from 4000-7600 rpm←Rob anyluck with the write up yet? can you say which NX system it is? my mechanic will want to go through the details with me (us dumb bunnyies ) Link to comment Share on other sites More sharing options...
JHEIII874T5M Posted September 1, 2005 Report Share Posted September 1, 2005 I think Rob just has the general, regular, old system. All you have to do is drill a hose in the hose prior to the throttle body, put a switch on your pedal, feed the nitrous line, tap your fuel line, and hit it. Link to comment Share on other sites More sharing options...
Guest Guest Posted September 1, 2005 Report Share Posted September 1, 2005 I think Rob just has the general, regular, old system. All you have to do is drill a hose in the hose prior to the throttle body, put a switch on your pedal, feed the nitrous line, tap your fuel line, and hit it.NX Tech support pointed me to this page:http://www.nitrousexpress.com./Instructions/main.htmI'm guessing the stage 1 EFI kit is the right one. although i don't understand how it works with a dual turbo.http://www.nitrousexpress.com./Instructions/stage1.pdf Link to comment Share on other sites More sharing options...
ROB @ VMS Posted September 1, 2005 Report Share Posted September 1, 2005 Im using the EFI stage 1 system. Nitrous is going to be injected before the throttle body. Having a twin turbo setup doesnt matter because it going into the motor after the turbo. I havent had a chance to do the write up yet as i have been busy at work. I will let everyone know asap tho. What you need is the Nx Efi kit. Link to comment Share on other sites More sharing options...
Guest Guest Posted September 1, 2005 Report Share Posted September 1, 2005 Im using the EFI stage 1 system. Nitrous is going to be injected before the throttle body. Having a twin turbo setup doesnt matter because it going into the motor after the turbo. I havent had a chance to do the write up yet as i have been busy at work. I will let everyone know asap tho. What you need is the Nx Efi kit.awesome rob! i've been trying to work with my mechanic (who knows a lot about this stuff) to ensure it's a reasonable thing to install. He likes to do stock upgrades or performance parts from IPD only. no problem there, i've got some really nice work done, and the car is a pleasure to drive. he's balking at this because it's not an obvious volvo made 3rd party option. however, the NX's tech support email thread, and some instructions, and an endourse meant from you (a demonstrable expert) it's going to get easier thanks!John Link to comment Share on other sites More sharing options...
SkyWriter Posted September 1, 2005 Author Report Share Posted September 1, 2005 awesome rob! i've been trying to work with my mechanic (who knows a lot about this stuff) to ensure it's a reasonable thing to install. He likes to do stock upgrades or performance parts from IPD only. no problem there, i've got some really nice work done, and the car is a pleasure to drive. he's balking at this because it's not an obvious volvo made 3rd party option. however, the NX's tech support email thread, and some instructions, and an endourse meant from you (a demonstrable expert) it's going to get easier thanks!John←yes, it was me again... i don't get it, i have remember me checked and stuff... in fact i thought it said my user name somewhere on the page. Link to comment Share on other sites More sharing options...
Guest Guest Posted September 24, 2005 Report Share Posted September 24, 2005 BUMP! Rob (ROB @ VMS) i know it's always tough to get these things down, just wondering if the idea worked out?Thanks!SkyWriter (if i've forgetten to login AGAIN! ) Link to comment Share on other sites More sharing options...
TorqueSteer Posted September 25, 2005 Report Share Posted September 25, 2005 I have finished installing A NX wet shot on my 850. With the 35 shot jets, it is running to rich, about 10.7-10.9 afr's, therefore not producing too much power yet, I will upgrade to the 50 hp nitrous jet and keep the 35 hp fuel jet in there to try to lean it out to low 12's AFR's. I can post some pictures tommorow of every part of the system. Link to comment Share on other sites More sharing options...
