Veneficus Posted July 29, 2005 Report Share Posted July 29, 2005 How many years of work did that take you jeremy? Link to comment Share on other sites More sharing options...
exexpat Posted July 29, 2005 Report Share Posted July 29, 2005 <2, but I made a few updates (wheels, grill) after the car was built. That paint job/interior/engine bay/stereo had about 60k miles on it when those pics were taken.Edit: And it was built in 1994/1995 (in case I get yellow silicon hose haters ) Link to comment Share on other sites More sharing options...
Veneficus Posted July 29, 2005 Report Share Posted July 29, 2005 Do I see image dynamics horns? Link to comment Share on other sites More sharing options...
exexpat Posted July 29, 2005 Report Share Posted July 29, 2005 ID2 Comps, fully reconstructed under dash and dual alesis 30-band studio eq'sEdit: I was IASCA regional Novice points champ in 1-150 watt sound quality 1995 ;) Link to comment Share on other sites More sharing options...
BeachRat Posted July 29, 2005 Report Share Posted July 29, 2005 It looks kind of unsettling, like the motor for a power wheel.←No kidding! What would you do with half the stuff that makes your car run?? Maybe an older Volvo, but not 93+... Would you run everything inside the fenders? Link to comment Share on other sites More sharing options...
Guest Guest_vclvc_* Posted July 29, 2005 Report Share Posted July 29, 2005 from what gathered by looking more closely at the engine bay, there are 'faux' firewall sections to hide a lot of the engine stuff. if you look at the pic closely, there is a plastic cap thing on the driver side hood hinge, and another cover plate by the hinge on the passenger side. there is also, i think, another plate on the bottom side of the firewall...and i think its all dented to look like its the real thing.i do think that they run a lot of their stuff inside the fenders, hidden unside the frame rails, wrapped in fake coolant hose, and underneath those plates.quite honestly, i think it looks really nice, although the turbo'd 240 someone posted here is also very nice with clean exposed wiring.i really give the first guy to do it a lot of credit. to think it, do it, and have it come out good is pretty impressive. Link to comment Share on other sites More sharing options...
Chris_R Posted July 29, 2005 Report Share Posted July 29, 2005 I love looking at your car Jeremy... Reminds me of when I was SO into audio. Alesis EQs, ID horns and Carver amps. Carver amps were the ... Still command a ton of cash on Ebay from those who know. Link to comment Share on other sites More sharing options...
fastboy Posted July 29, 2005 Report Share Posted July 29, 2005 Now I miss my MKII.I would love to see a Volvo with a smoothed enginbay with all the welds moulded. But that would be a whole lot more work than doing one on a dub. If I had a spare Volvo I would maybe do that, but it would more likely end up as a track car. Link to comment Share on other sites More sharing options...
Chris_R Posted July 29, 2005 Report Share Posted July 29, 2005 The race-prepped S60 that we saw at the Volvo S40 test drive had the bay cleaned up nicely. The mounts for the strut brace were welded/smoothed/painted to the chassis. Sorry, I can't seem to find the pics anymore. Link to comment Share on other sites More sharing options...
Guest DougK Posted July 29, 2005 Report Share Posted July 29, 2005 quite honestly, i think it looks really nice, although the turbo'd 240 someone posted here is also very nice with clean exposed wiring.←The trick would be, (now that Im doing another one) is to weld every hole shut in the engine bay and grind them smooth. Then, I would drill a single firewall grommet behind the cylinder head of the motor, or just above the transmission bellhousing. Then I could run all the wiring for the sensors, injectors, TPS ect up along the back of the motor and then under the intake. That would make for almost 0 visable wiring. Obviously, I have to have *some* wiring visable (mostly battery cable to the starter) but thats about it. Nice thing is, on the new car, the T6 motor has the alternator on the same side as the starter... so thats even less wiring. Link to comment Share on other sites More sharing options...
exexpat Posted July 29, 2005 Report Share Posted July 29, 2005 The trick would be, (now that Im doing another one) is to weld every hole shut in the engine bay and grind them smooth. Then, I would drill a single firewall grommet behind the cylinder head of the motor, or just above the transmission bellhousing. Then I could run all the wiring for the sensors, injectors, TPS ect up along the back of the motor and then under the intake. That would make for almost 0 visable wiring. Obviously, I have to have *some* wiring visable (mostly battery cable to the starter) but thats about it. Nice thing is, on the new car, the T6 motor has the alternator on the same side as the starter... so thats even less wiring.←You won't see it if you relo the battery and run 4ga to the starter under the car and terminate with black loom. Link to comment Share on other sites More sharing options...
Chris_R Posted July 29, 2005 Report Share Posted July 29, 2005 You won't see it if you relo the battery and run 4ga to the starter under the car and terminate with black loom.←Dang... You beat me to it! Link to comment Share on other sites More sharing options...
Guest DougK Posted July 29, 2005 Report Share Posted July 29, 2005 I did have a battery in the trunk, I just didn't want to run the cable under the car (and it was 1/0 gauge ). It worked out though, good 'nuff for me. Link to comment Share on other sites More sharing options...
gdizzle Posted July 29, 2005 Report Share Posted July 29, 2005 If you go through the vortex galleries for waterfest11, you'll see it's all the rage... Link to comment Share on other sites More sharing options...
exexpat Posted July 29, 2005 Report Share Posted July 29, 2005 for under car, it's all about the metal conduit... Link to comment Share on other sites More sharing options...
