CaliS80T6 Posted July 29, 2005 Report Share Posted July 29, 2005 00 S80 Turbo modelHave a front end clunk that appears to settle itself itself out after 10-miles. There is no slop in the steering and no tire vibration. Possibly the stabilizer bushings? Noise in coming from under the left front, feels like it is right under the driver's dead pedal. Link to comment Share on other sites More sharing options...
jbuck Posted July 29, 2005 Report Share Posted July 29, 2005 A clunk when you go over the bumpies? Spring seat?I had a minor one recently that was a missing front caliper retaining spring. That was a quiet metallic clunk. Link to comment Share on other sites More sharing options...
howardc64 Posted August 2, 2005 Report Share Posted August 2, 2005 00 S80 Turbo modelHave a front end clunk that appears to settle itself itself out after 10-miles. There is no slop in the steering and no tire vibration. Possibly the stabilizer bushings? Noise in coming from under the left front, feels like it is right under the driver's dead pedal.←Had a right front clunk over bumps. Was the right strut/spring seat (part $33, labor@indy $75) They said the left strut/spring seat was cracked too. No clunk there yet. Link to comment Share on other sites More sharing options...
CaliS80T6 Posted September 7, 2005 Author Report Share Posted September 7, 2005 Well finally had enough and took it to the professionals. WOW, that hurt.Turns out the bushings went out and the struts needed to be rebuilt. 1100 all total but it is good to have it back on the road. Had this awful tire hum too. Hopefully it was due to the lug nuts being on so tight. WOW, almost had to crank up the pressure on the compressor to get them off. Link to comment Share on other sites More sharing options...
the underlørd Posted September 7, 2005 Report Share Posted September 7, 2005 the struts needed to be rebuilt. ←? new Koni shocks are only 600 for all 4 for your car. they seriously "fixed" your stock ones? jeez man. Link to comment Share on other sites More sharing options...
yangotang Posted September 7, 2005 Report Share Posted September 7, 2005 Had this awful tire hum too. Hopefully it was due to the lug nuts being on so tight. WOW, almost had to crank up the pressure on the compressor to get them off.←Tire hum? Sounds quite silly, but have you checked your tire pressure? How tight your tires are shouldn't create a humming noise.Please put your location into your profile :) Link to comment Share on other sites More sharing options...
stu.f Posted September 8, 2005 Report Share Posted September 8, 2005 I have this problem as well, replaced lower ball joint, and have bilsitens on as well, and the sway bar bushings seem to be fine as well. Link to comment Share on other sites More sharing options...
Nebor Posted September 8, 2005 Report Share Posted September 8, 2005 I have a similar problem. I hear a low rumple...followed by a metallic 'squink'... ...followed by a mysterious...'glonk.' Link to comment Share on other sites More sharing options...
mikie Posted September 8, 2005 Report Share Posted September 8, 2005 I was getting some strange noises every once in a while, then I installed slater's end links everything went away. I was told that end links would constantly make poping noises but mine went and came... Link to comment Share on other sites More sharing options...
