Xero Posted July 29, 2005 Report Share Posted July 29, 2005 Hi, guys and girls. I have a 2002 S40. Here is my issue. When I am accelerating, I here a moaning sound coming from under the hood. It seems to be coming from the passenger side, but I can't be 100% sure. I have recently installed a Dawes boost controller and I am set at 10 psi. Could this be the culprit? Any help would be greatly appreciated. Link to comment Share on other sites More sharing options...
TorqueSteer Posted July 30, 2005 Report Share Posted July 30, 2005 Is the performance affected in any way? If you think that the Dawes is the culprit, remove it and see what happens. Link to comment Share on other sites More sharing options...
maiku Posted July 30, 2005 Report Share Posted July 30, 2005 does it sound like anything is rubbing against something? Link to comment Share on other sites More sharing options...
Xero Posted July 30, 2005 Author Report Share Posted July 30, 2005 I re-routed the b/c and no difference. I am not sure if it is something rubbing, but it sounds like a cow "mooing". It only happens when I am under boost and hard acceleration. Link to comment Share on other sites More sharing options...
Xero Posted July 30, 2005 Author Report Share Posted July 30, 2005 Also, performance does not seem to be affected. However, I have gone from 27 mpg to 20 mpg. Link to comment Share on other sites More sharing options...
MrWinkey Posted July 31, 2005 Report Share Posted July 31, 2005 Possible boost leak sneakin out somewhere? Not affecting performance but making the noise...tighten all your intake hose clamps?...sorry best I can do over cyber repair? B) Link to comment Share on other sites More sharing options...
Xero Posted August 1, 2005 Author Report Share Posted August 1, 2005 Thanks for the help. I believe that it was a boost leak. I reran all of the vac lines and I think that it is fixed. Link to comment Share on other sites More sharing options...
gdizzle Posted August 1, 2005 Report Share Posted August 1, 2005 maybe it's a cat :monkey: Link to comment Share on other sites More sharing options...
Xero Posted August 2, 2005 Author Report Share Posted August 2, 2005 I fixed the whole boost controller problem, but I think that it is the charge pipes leaking, so I will try to tighten them down and see. Link to comment Share on other sites More sharing options...
