Spetsnaz Op Posted August 1, 2005 Report Share Posted August 1, 2005 Ok. I need to get some oil out of a V70 XC, because I overfilled it Is there another way to get some out without using the drain plug? If not, I need to know the size of the socket needed as none in my current 94 piece set will fit. Also I need to know if I can just reuse all the washers and stuff since I will only be removing a quart or 3. Thanks. Link to comment Share on other sites More sharing options...
Bay13 Posted August 2, 2005 Report Share Posted August 2, 2005 17mm drain plug, stock. Just flip the washer over and use it one time more won't hurt.If you have one of those hand vac pumps you could put hose down the dip stick tube and suck it out. Link to comment Share on other sites More sharing options...
