FINN Posted April 23, 2004 Report Share Posted April 23, 2004 how? i have a pioneer headunit i want to put in but i believe it would interfere w/ the stock amp. help :blink: Link to comment Share on other sites More sharing options...
ginkof Posted April 24, 2004 Report Share Posted April 24, 2004 in most Volvos the stock amp is intigrated with the head unit so when you take your radio out the amp gets taken out too. Since you have an R model there is a chance that it might be different. If it is sorry im not being such a help. Link to comment Share on other sites More sharing options...
FINN Posted April 25, 2004 Author Report Share Posted April 25, 2004 Yeah i do have the amp. The deck has a an output leading off into an amp somewhere...i still have to find it. But thanks anyways. Link to comment Share on other sites More sharing options...
550 Posted April 25, 2004 Report Share Posted April 25, 2004 Well, you should get a wiringin kit from crutchfield.com they will be able to give you a amp bypass crossover harness, (lot of mombo jumbo there) but it should help you out. Link to comment Share on other sites More sharing options...
FINN Posted April 27, 2004 Author Report Share Posted April 27, 2004 appreciate it. Where is the the amp located? Only place left that i havent looked is somewhere around the passenger glove compartment. Link to comment Share on other sites More sharing options...
jb7073 Posted April 27, 2004 Report Share Posted April 27, 2004 What do you plan on doing with your amp? Link to comment Share on other sites More sharing options...
550 Posted April 28, 2004 Report Share Posted April 28, 2004 Possible amp locations:Under driver/passenger front seatsto the left of the steering column, but you have to take the kick plate/cover off there the accelerator is. It may be under the dash, you should see it right away it will have heat sinks on it. Good luckLater Link to comment Share on other sites More sharing options...
r850glt Posted May 18, 2004 Report Share Posted May 18, 2004 Your stock amp is located in front of the heater core. not in the glove box Link to comment Share on other sites More sharing options...
