montgom Posted August 7, 2005 Report Share Posted August 7, 2005 Well, I was tightening the petcock on my radiator and snap. It is now broken. No petcock on my poor little radiator. Any idea what I do next other than look stupid? How do I fix it? Bob Link to comment Share on other sites More sharing options...
Bay13 Posted August 7, 2005 Report Share Posted August 7, 2005 The part number for a new "Drain Cock" as parts calls it is 3547226.As far as looking stupid, you now look like every techinician in the shop I work at, we have all broke those plastic pet cocks. Problem is that it's plastic and a 13mm socket takes it off and it's so easy to over tighten it and the thing breaks. If you get down and look at whats let, a HEX will fit up in the hole. Make sure you have the new one before you start messing with taking out the old one. With a new one in hand it's easier to figure out what size hex fits up there. The good news is that when they break it is usually when tightening them after a radiator drain, and they break off seated tight enough to not cause any leakage. Link to comment Share on other sites More sharing options...
montgom Posted August 7, 2005 Author Report Share Posted August 7, 2005 The part number for a new "Drain Cock" as parts calls it is 3547226.As far as looking stupid, you now look like every techinician in the shop I work at, we have all broke those plastic pet cocks. Problem is that it's plastic and a 13mm socket takes it off and it's so easy to over tighten it and the thing breaks. If you get down and look at whats let, a HEX will fit up in the hole. Make sure you have the new one before you start messing with taking out the old one. With a new one in hand it's easier to figure out what size hex fits up there. The good news is that when they break it is usually when tightening them after a radiator drain, and they break off seated tight enough to not cause any leakage.←Thanks (again ) So all I have to do is look up and I will see a little hex. Thanks. When I removed the socket wrench, there inside it was this hunk of plastic. About 1 cm long. The surface on the underside of the radiator was smooth and everything was flush. Next week I will get two these little petcocks. One in reserve for the next time i break it!Any tips on how "tight" to urn the petcock? I did not think I had overdone it the first time.Once again, thanks.Bob Link to comment Share on other sites More sharing options...
