DouginDenver Posted August 9, 2005 Report Share Posted August 9, 2005 My headlight switch went bad last night - middle postion turns on instrument panel lights, but the full on postion gives headlights and no panel lights unless I push in on the switch. How does it come out for replacement? If it just prys out, is it from the bottom, top or sides? Link to comment Share on other sites More sharing options...
2005V70R Posted August 9, 2005 Report Share Posted August 9, 2005 My headlight switch went bad last night - middle postion turns on instrument panel lights, but the full on postion gives headlights and no panel lights unless I push in on the switch. How does it come out for replacement? If it just prys out, is it from the bottom, top or sides?←Same thing happened to me. Pry out the the inner area of the switch...not the bigger square part. You may be able to grab the knob and pull straight out...that is the piece you are replacing. Replacement switch is cheap ~$25. Link to comment Share on other sites More sharing options...
DouginDenver Posted August 9, 2005 Author Report Share Posted August 9, 2005 Same thing happened to me. Pry out the the inner area of the switch...not the bigger square part. You may be able to grab the knob and pull straight out...that is the piece you are replacing. Replacement switch is cheap ~$25.←So you are saying that the larger gray plastic bezel stays in place in the dash, and the switch pulls straight out of that? I would not have guessed that. Link to comment Share on other sites More sharing options...
Oreo931 Posted August 9, 2005 Report Share Posted August 9, 2005 bring it to the dealer...they will do everything for free...this piece was recalled for problems like this.... Link to comment Share on other sites More sharing options...
the underlørd Posted August 9, 2005 Report Share Posted August 9, 2005 So you are saying that the larger gray plastic bezel stays in place in the dash, and the switch pulls straight out of that? I would not have guessed that.←the whole sqaure peice comes out. Link to comment Share on other sites More sharing options...
2005V70R Posted August 9, 2005 Report Share Posted August 9, 2005 bring it to the dealer...they will do everything for free...this piece was recalled for problems like this....←True, but only if his VIN matches the recall Link to comment Share on other sites More sharing options...
V70-AAAHHHRRR Posted August 9, 2005 Report Share Posted August 9, 2005 True, but only if his VIN matches the recall←Doug, you can always go to carfax.com without paying anything, enter your VIN, and see if it comes up with any open recalls.If it does, your dealer will be able to find out exactly which ones, and should rectify any/all at no charge.Just got my headlight switch replaced under recall after realizing it was broken and fixing it (temporarily) with a paperclip.-KB Link to comment Share on other sites More sharing options...
DouginDenver Posted August 9, 2005 Author Report Share Posted August 9, 2005 the whole sqaure peice comes out.←OK, but HOW does it come out? Just pry? Top, bottom or sides? Link to comment Share on other sites More sharing options...
the underlørd Posted August 9, 2005 Report Share Posted August 9, 2005 OK, but HOW does it come out? Just pry? Top, bottom or sides?←all of the above! take a small headed flathead screwdriver, and put a lil bit of electrical tape on it, and use it to pry out from all 4 sides. Link to comment Share on other sites More sharing options...
2005V70R Posted August 9, 2005 Report Share Posted August 9, 2005 Doug, you can always go to carfax.com without paying anything, enter your VIN, and see if it comes up with any open recalls.If it does, your dealer will be able to find out exactly which ones, and should rectify any/all at no charge.Just got my headlight switch replaced under recall after realizing it was broken and fixing it (temporarily) with a paperclip.-KB←You can also call the dealer and he'll run your VIN for free Link to comment Share on other sites More sharing options...
V70-AAAHHHRRR Posted August 9, 2005 Report Share Posted August 9, 2005 OK, but HOW does it come out? Just pry? Top, bottom or sides?←If it helps or makes you more comfortable with it:1.) Remove the hex screw in the center of the panel over the driver's knees2.) Remove the panel itself3.) Reach on up in there and push it out from the inside.-KB Link to comment Share on other sites More sharing options...
Bay13 Posted August 9, 2005 Report Share Posted August 9, 2005 It is not easy to pry out the head light switch, and I wouldn't. It is easy to pry out the dimmer switch just to the right of the head light switch. Pryout the dimmer, and then stick your finger in the hole where the dimmer switch goes and push the back of the head light switch as you gently pull on the knob wiggling it a bit. Link to comment Share on other sites More sharing options...
highspeed11 Posted August 10, 2005 Report Share Posted August 10, 2005 Since it's a '99 it's going to fall under the recall. C142I just pull off the knob with my fingers and then pull out the switch with pliers. They'll(the dealer)replace it for you so don't waste your time with it. They replace it if the tabs are broken or it is of the wrong part number. Link to comment Share on other sites More sharing options...
