Slonik Posted August 10, 2005 Report Share Posted August 10, 2005 1999 V70R..sometimes, but not everytime, the radiator fan continues working for about 5-7 minutes after the car is shut off... this seems really weird. i can see it working for a few seconds, that's normal... but that long? is that normal? it seems like too much of a battery drain. Link to comment Share on other sites More sharing options...
Selena Posted August 10, 2005 Report Share Posted August 10, 2005 1999 V70R..sometimes, but not everytime, the radiator fan continues working for about 5-7 minutes after the car is shut off... this seems really weird. i can see it working for a few seconds, that's normal... but that long? is that normal? it seems like too much of a battery drain.←If I recall Correctly its normal. There was a recall on later cars but for yours it is normal. Link to comment Share on other sites More sharing options...
jleilich Posted August 10, 2005 Report Share Posted August 10, 2005 this is normal , they can run for quite a while it depends on how long it takes to cool it down. Its on a thermostat Link to comment Share on other sites More sharing options...
StickThatClutch Posted August 10, 2005 Report Share Posted August 10, 2005 Its actual not normal for a non-P2 car. However, if its really hot and you've been running your engine hard it will stay on for a bit. P2's have a fan to clear the moisture out of the HVAC system and can run for 20 minutes. My older FWD has had the fan on for maybe 5 mintues but this is a rare occurance only after I beat the heck out of the car. Link to comment Share on other sites More sharing options...
Vos Posted August 11, 2005 Report Share Posted August 11, 2005 1999 V70R..sometimes, but not everytime, the radiator fan continues working for about 5-7 minutes after the car is shut off... this seems really weird. i can see it working for a few seconds, that's normal... but that long? is that normal? it seems like too much of a battery drain.←I have a '99 T5 that does the same thing, at least on the occaisions where I really hit the boost for long periods of time before shutting down. I live in College Station, Texas, where for the past 2 months the temperature has been over 105 °F every day in the afternoon. Coming home from work, boosting 12-14PSI for a large percentage of the drive (lots of passing on the freeway), it does it quite a bit. But on cool mornings, not boosting much, never a problem. When it does stay on, it always shuts down after 3-5 minutes...Now, I did have a '98 S70 GLT that had a pre-heat fan relay blow out, and it stayed on for 45 minutes before I finally yanked the relay out... But that was not the primary fan, rather the auxilliary fan that's inline with the intake on the "98 GLTs.My dos centavos;) Good luck! Link to comment Share on other sites More sharing options...
