medicT5 Posted August 10, 2005 Report Share Posted August 10, 2005 So after leaving all my windows cracked to keep the car cooler all day my driver side rear window now will not move.... neither the front control or the rear work... could it be something simple ? Link to comment Share on other sites More sharing options...
MrWinkey Posted August 10, 2005 Report Share Posted August 10, 2005 Try spraying a bit of contact cleaner under the switch (master switch) for that window and rock it back and forth several times with the key off then turn the key on and try it. That may fix it and if does you may eventually need a master switch assembly Link to comment Share on other sites More sharing options...
850drag Posted August 11, 2005 Report Share Posted August 11, 2005 So after leaving all my windows cracked to keep the car cooler all day my driver side rear window now will not move.... neither the front control or the rear work... could it be something simple ?←Its the master switch buddy. usually when something like that happens thats what it is. especially since the front doesn't work well. Link to comment Share on other sites More sharing options...
medicT5 Posted August 12, 2005 Author Report Share Posted August 12, 2005 I guess I got lucky... the next day when I started it up the window worked fine... hopefully it was just a one time thing.. but if not then looks like I'll be spending some cash..... Link to comment Share on other sites More sharing options...
