biged30 Posted August 12, 2005 Report Share Posted August 12, 2005 After checking the CEL with my OBDII reader it came up with engine running rich. From reading other post I assume it is either a bad oxygen sensor or MAF sensor. The car doe run a slow on acceleration but gas mileage is still good (27 mpg). What is the eaiest and cheapest way to eliminate one or both of those possibilities? Also I just changed out all 5 plugs, wires, cap and rotor and the codes for misfures came up on number 3 and 5. Did I just plug something in wrong? I appreciate any and all help. Link to comment Share on other sites More sharing options...
Zappo Posted August 12, 2005 Report Share Posted August 12, 2005 After checking the CEL with my OBDII reader it came up with engine running rich. From reading other post I assume it is either a bad oxygen sensor or MAF sensor. The car doe run a slow on acceleration but gas mileage is still good (27 mpg). What is the eaiest and cheapest way to eliminate one or both of those possibilities? Also I just changed out all 5 plugs, wires, cap and rotor and the codes for misfures came up on number 3 and 5. Did I just plug something in wrong? I appreciate any and all help.←0172? If that is the code you got, it could be something as simple as a vacuum leak. Link to comment Share on other sites More sharing options...
