Guest Guest_dlugi_* Posted August 14, 2005 Report Share Posted August 14, 2005 please help with the following:I get message "check stop lamp" when pressing brake pedal;main brake lights are not coming on, spoiler lights works;checked bulbs for main brake lights, they are ok.car is 02V70;thanks for your help Link to comment Share on other sites More sharing options...
Bay13 Posted August 14, 2005 Report Share Posted August 14, 2005 You checked the bulb, and said they are good, assuming this is correct then there is not power at the socket, you might check for that. After that you are talking a visit to a repair facility. The CEM (central electronic module) up front sends a request back to the REM, (Rear electronic module) for the lights to be turned on. That whole flow line from the brake pedal to the socket will need to be checked ouit with a schematic and multimeter to figure out the problem. Link to comment Share on other sites More sharing options...
Guest Guest_dlugi_* Posted August 14, 2005 Report Share Posted August 14, 2005 You checked the bulb, and said they are good, assuming this is correct then there is not power at the socket, you might check for that. After that you are talking a visit to a repair facility. The CEM (central electronic module) up front sends a request back to the REM, (Rear electronic module) for the lights to be turned on. That whole flow line from the brake pedal to the socket will need to be checked ouit with a schematic and multimeter to figure out the problem.←I'm going to check for power in sockets; clean contacts as well;my spoiler brake light still works.......would this be on the same loop as main brake lights ? Link to comment Share on other sites More sharing options...
Guest Guest_dlugi_* Posted August 14, 2005 Report Share Posted August 14, 2005 I'm going to check for power in sockets; clean contacts as well;my spoiler brake light still works.......would this be on the same loop as main brake lights ?←SB36-0024-0204 talks about brake light relay recall campaign no.131 for certain v70 2002where is that relay located ? Link to comment Share on other sites More sharing options...
Guest Guest_dlugi_* Posted August 14, 2005 Report Share Posted August 14, 2005 SB36-0024-0204 talks about brake light relay recall campaign no.131 for certain v70 2002where is that relay located ?←why car manufacturers don't post relays map/guide only fuses ? Link to comment Share on other sites More sharing options...
Bay13 Posted August 14, 2005 Report Share Posted August 14, 2005 It's located on the REM, thats drivers side rear if you take out the trim to change the light you can see part of the REM. Don't recall the exact location of that relay. (could be the problem) Link to comment Share on other sites More sharing options...
highspeed11 Posted August 14, 2005 Report Share Posted August 14, 2005 The relay is on the REM. Not sure which one. I think it's RMI5 or 15. The recall involves replacing the single relay with two on a few vehicles. Try gently tapping on the REM with the brake pedal depressed to see if the brake lights flicker. Why not take it to the dealer? Check for open recalls? Link to comment Share on other sites More sharing options...
Serge Posted August 14, 2005 Report Share Posted August 14, 2005 Rich: Our 2002 S60 has an issue where the bulb's heat melts the bulb holder. It cause the contacts to move and short. I fixed it temporarily but it continue to move and sometimes the bulb goes out (doesn't make a contact).I assume that this is a problem with the design (the other side holder is okay though), was there a recall for this? Link to comment Share on other sites More sharing options...
Guest Guest_dlugi_* Posted August 14, 2005 Report Share Posted August 14, 2005 The relay is on the REM. Not sure which one. I think it's RMI5 or 15. The recall involves replacing the single relay with two on a few vehicles. Try gently tapping on the REM with the brake pedal depressed to see if the brake lights flicker. Why not take it to the dealer? Check for open recalls?←thanksits RMI 5 & 6 position; these relays are under the trim (which I hate touching ), but there is a single bolt at the bottom of the panel, that looks like a holding bolt for the whole panel, am I right to unbolting and sliding the whole panel out to the back in order to expose relays for the removal ?......just trading here lightly Link to comment Share on other sites More sharing options...
highspeed11 Posted August 14, 2005 Report Share Posted August 14, 2005 To remove that panel there's a single 10mm in the top corner where the cargo cover sits near the rear seatback. The bolt I'm assuming that you're talking about is, another 10mm that holds the multi-connector to the REM. Once you remove the side panel just push up on the tap and pull out to release the REM if you need to. You shouldn't have to remove the REM though unless you're checking the connection at the relays. You can pull the relays out without removing the REM.by the way: I assume the fuse(#2 I think?)is good? Link to comment Share on other sites More sharing options...
Bay13 Posted August 15, 2005 Report Share Posted August 15, 2005 Rich: Our 2002 S60 has an issue where the bulb's heat melts the bulb holder. It cause the contacts to move and short. I fixed it temporarily but it continue to move and sometimes the bulb goes out (doesn't make a contact).I assume that this is a problem with the design (the other side holder is okay though), was there a recall for this?I've not seen or remember a recall for what you describe. 2002 should be under warranty still, unless your mileage is over 50K. If it's still covered under warranty take it in and show them so they will replace it. If it's out of warranty, get ahold of FCPgroton for the part. Link to comment Share on other sites More sharing options...
Guest Guest_dlugi_* Posted August 15, 2005 Report Share Posted August 15, 2005 To remove that panel there's a single 10mm in the top corner where the cargo cover sits near the rear seatback. The bolt I'm assuming that you're talking about is, another 10mm that holds the multi-connector to the REM. Once you remove the side panel just push up on the tap and pull out to release the REM if you need to. You shouldn't have to remove the REM though unless you're checking the connection at the relays. You can pull the relays out without removing the REM.by the way: I assume the fuse(#2 I think?)is good?←thanks highspeed, yes I checked bulbs+fuse;I did remove panel and removed the relay; tried to use 2 relays from 03MY car; no effect; parts no. of these 2 relays from 03 MY are different from what SB calls to use ie.8651661, maybe that's the reason........I know some of you may think I am nuts, will burn, damage parts......but can not help it......the equiring mind I hope Im still on the right track.......if this were a brake switch, the spoiler light would not work either, right ?regards Link to comment Share on other sites More sharing options...
Bay13 Posted August 15, 2005 Report Share Posted August 15, 2005 The spoiler(3rd brake light) and the brake lights could be activated differently but via the Rear electronic module REM. Again need the wiring diagram. Link to comment Share on other sites More sharing options...
highspeed11 Posted August 15, 2005 Report Share Posted August 15, 2005 Did you ever try tapping on the REM? Check the connection on the back where the relays go and also jiggle the multi-connector at the bottom. If your bulbs are ok you may have several DTCs set.I'm not sure we can help you much further without a wiring diagram or any DTCs. I'm not sure the part numbers matter. I think all relays on the REM(I could be mistaken)are the same part number now. Link to comment Share on other sites More sharing options...
Serge Posted August 15, 2005 Report Share Posted August 15, 2005 I've not seen or remember a recall for what you describe. 2002 should be under warranty still, unless your mileage is over 50K. If it's still covered under warranty take it in and show them so they will replace it. If it's out of warranty, get ahold of FCPgroton for the part.←Okay, gotcha. Thanks Rich! I'll see what they say about it. Link to comment Share on other sites More sharing options...
