dlugi Posted August 16, 2005 Report Share Posted August 16, 2005 Did you ever try tapping on the REM? Check the connection on the back where the relays go and also jiggle the multi-connector at the bottom. If your bulbs are ok you may have several DTCs set.I'm not sure we can help you much further without a wiring diagram or any DTCs. I'm not sure the part numbers matter. I think all relays on the REM(I could be mistaken)are the same part number now.←thanks for all the inputI did install 2 relays 8651661 as per SB mentioned before; apparently my car did not fall under the recall.......go figure this one out :angry: Link to comment Share on other sites More sharing options...
