vstylz Posted August 18, 2005 Report Share Posted August 18, 2005 http://volvospeed.com/vs_forum/index.php?showtopic=29401im just posting here so there may be a little more exposure to this... im really heated about this and hopefully someone will know the answer or can lead me in the right way.I hope this doesnt get deleted :( Link to comment Share on other sites More sharing options...
the underlørd Posted August 18, 2005 Report Share Posted August 18, 2005 http://volvospeed.com/vs_forum/index.php?showtopic=29401im just posting here so there may be a little more exposure to this... im really heated about this and hopefully someone will know the answer or can lead me in the right way.I hope this doesnt get deleted ←have you had the symptoms of this?I've never heard of anyone having it, so I'm curious if you do.honest. it's good to get this out there, I'm sure a lot of people don't know about it. Link to comment Share on other sites More sharing options...
vstylz Posted August 18, 2005 Author Report Share Posted August 18, 2005 do you have a ECU upgrade? cause if you do, and you get it refashed by the dealer.. you don't have an ECU upgrade anymore. as for the number.. i used to have it written down somewhere.. but.. no dice.←I think it is very important to get this out there too..To answer your question, yes sometimes while drive with my foot constant on the throttle all of a sudden the car will stutter for a split second and then go back to normal again... itll happen once or twice a trip... it has happened the RPM flucuation/suttering occurred while i am stopped at a red light or when i just turn on the car...it IS due to a faulty ECM that needs an update... Link to comment Share on other sites More sharing options...
the underlørd Posted August 18, 2005 Report Share Posted August 18, 2005 I think it is very important to get this out there too..To answer your question, yes sometimes while drive with my foot constant on the throttle all of a sudden the car will stutter for a split second and then go back to normal again... itll happen once or twice a trip... it has happened the RPM flucuation/suttering occurred while i am stopped at a red light or when i just turn on the car...it IS due to a faulty ECM that needs an update...←I had those symptoms, although slightly more major than that.. it turned out to be a bad MAF... so that's alwsys something to be cognizant of too... but this doesn't sound like a MAF. Link to comment Share on other sites More sharing options...
Nebor Posted August 18, 2005 Report Share Posted August 18, 2005 Here's the info you need to fight. I still don't think it will help you win, but good luck.http://www.brickboard.com/ARCHIVES/1999JUN/10012464.shtml Link to comment Share on other sites More sharing options...
vstylz Posted August 18, 2005 Author Report Share Posted August 18, 2005 I had those symptoms, although slightly more major than that.. it turned out to be a bad MAF... so that's alwsys something to be cognizant of too... but this doesn't sound like a MAF.←Thats some good advice i actually thought it may be that too and the MAF is a problem on these cars but im pretty sure its not the case here.. not yet at least :monkey: Link to comment Share on other sites More sharing options...
vstylz Posted August 18, 2005 Author Report Share Posted August 18, 2005 Here's the info you need to fight. I still don't think it will help you win, but good luck.http://www.brickboard.com/ARCHIVES/1999JUN/10012464.shtml←OMG that may be it!... I have to go into a meeting in about 10 minutes but im goig to look into this further... beleive me if this is it then i've already WON... Thank you Nebor! Link to comment Share on other sites More sharing options...
gdizzle Posted August 18, 2005 Report Share Posted August 18, 2005 Thats some good advice i actually thought it may be that too and the MAF is a problem on these cars but im pretty sure its not the case here.. not yet at least ←Disconnect the MAF while the car is runing. If the problem goes away, then well, it's the MAF! You know Rich(bay13admin) works a NOVA dealer.... Link to comment Share on other sites More sharing options...
