rodrigo Posted August 20, 2005 Report Share Posted August 20, 2005 this is for a '97 GLT.when i have the heat/ACon, and i point the air to come out of the floor vents...nothing comes out. only out of the top, or face, vents. is this common?how do i diagnose it? :blink: Link to comment Share on other sites More sharing options...
Bay13 Posted August 20, 2005 Report Share Posted August 20, 2005 By using the Volvo Scan Tool (VST) you can do a damper motor cal, check for stored codes. If you have ECC, which is Electronic Climate Control. you have ECC if your right and left temp dials have numbers on them, if not then you have MCC. Manual Climate Control. If it's MCC, you could have a cable problem, or the controller thats inback of the face panel, it has all kinds of plastic cams that move the wires that go to the dampers. Or you could have a broken shaft that is suppose to move the flaps.So do you have MCC or ECC. Do you have a Volvo shop that has a Volvo Scan tool? Link to comment Share on other sites More sharing options...
rodrigo Posted August 20, 2005 Author Report Share Posted August 20, 2005 I have ECC because the climate control has the numbers....62-78, i think.So, I'm not sure what to do...I do not have a VST, but the shop i go to has one. However, i would rather not go there if i am going to try and do it myself. The guy there is really cool, and does very good work...i've been going there for years and always get the car back clean, fixed, and they are not too expensive, but most importantly ive never had to go back to get the same thing repaired again. so i dont want to piss the guy off because he's professional, and a pretty cool guy.maybe i should get a VST....i dont even know how much those are...its a little hand held, right? Link to comment Share on other sites More sharing options...
Bay13 Posted August 20, 2005 Report Share Posted August 20, 2005 The Volvo Scan Tool is about $6,400.00 last time I bought one. :P Link to comment Share on other sites More sharing options...
rodrigo Posted August 20, 2005 Author Report Share Posted August 20, 2005 <_< i could just give it to the mechanic......but thats no fun!!!!! Link to comment Share on other sites More sharing options...
