mlanctot Posted August 21, 2005 Report Share Posted August 21, 2005 Wife's car has clunking sound from the front end when traveling on rough roads. I suspect it to be strut bushings. Any thoughts on best way to repair. Link to comment Share on other sites More sharing options...
MrWinkey Posted August 21, 2005 Report Share Posted August 21, 2005 It's more than likely the spring perch(rubber mount ) on the strut. But the cheapest and easiest thing to do first would be the sway bar endlinks. Link to comment Share on other sites More sharing options...
Bay13 Posted August 21, 2005 Report Share Posted August 21, 2005 Agree ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^you can check the top strut mount, with a good flash light, look in the top of the strut, and bounce the car, while looking at the mount, if it's broke you can usually see it.The link rods are fairly easy to check as well, lay on the ground beside the front tire, legs facing forward, and reach in and grab ahold of the sway bar where the link rod attaches, now have someone bounce the car on that side, if the link rod is the problem you will feel the cluncking/looseness. Link to comment Share on other sites More sharing options...
mlanctot Posted August 22, 2005 Author Report Share Posted August 22, 2005 Agree ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^you can check the top strut mount, with a good flash light, look in the top of the strut, and bounce the car, while looking at the mount, if it's broke you can usually see it.The link rods are fairly easy to check as well, lay on the ground beside the front tire, legs facing forward, and reach in and grab ahold of the sway bar where the link rod attaches, now have someone bounce the car on that side, if the link rod is the problem you will feel the cluncking/looseness.←Finally got a chance to crawl under the car and yes its the sway bar links. Thanks for the suggestions. Link to comment Share on other sites More sharing options...
