nick S60 R Posted August 23, 2005 Report Share Posted August 23, 2005 Just order my s60r as some of you might know. Was thinking about getting a upgraded chip for the car and a down pipe. But was wonder what does the chip exactly do? Also whats the effiency of the turbo. How far can I take the stock turbo untill its just blowing hot air, basically what psi is the turbo out of its effiency psi. Also how well does the stock by pass valve work. What size is the turbo on the R. Thank you for all you help guys. :D Link to comment Share on other sites More sharing options...
Che'_Moderator Posted August 23, 2005 Report Share Posted August 23, 2005 Just order my s60r as some of you might know. Was thinking about getting a upgraded chip for the car and a down pipe. But was wonder what does the chip exactly do? Also whats the effiency of the turbo. How far can I take the stock turbo untill its just blowing hot air, basically what psi is the turbo out of its effiency psi. Also how well does the stock by pass valve work. What size is the turbo on the R. Thank you for all you help guys. ←The K24 turbo will go up more than enough to handle basic chip tuning. If your going to go above and beyond you should look into a hybrid turbo. The chip, depending on which one, is basically going to remove some limiters and raise the boost. Stock CBV will be more than enough for the volume you will be flowing Link to comment Share on other sites More sharing options...
nick S60 R Posted August 23, 2005 Author Report Share Posted August 23, 2005 The K24 turbo will go up more than enough to handle basic chip tuning. If your going to go above and beyond you should look into a hybrid turbo. The chip, depending on which one, is basically going to remove some limiters and raise the boost. Stock CBV will be more than enough for the volume you will be flowing←what ecm chip would you recommed? And what are the specs on the chip? Bascially i believe the R pushes out about 17psi from factory. So the chip might raise it to mabye 21psi?????????? Also if i get EBC how far can i push the turbo and the engine. Link to comment Share on other sites More sharing options...
ToxicLemonade Posted August 23, 2005 Report Share Posted August 23, 2005 what ecm chip would you recommed? And what are the specs on the chip? Bascially i believe the R pushes out about 17psi from factory. So the chip might raise it to mabye 21psi?????????? Also if i get EBC how far can i push the turbo and the engine.←PM boosted S60R, he has pretty much pushed his car to the limits with i believe the stock turbo. he went with RICA for ecu tuning and some other goodies. -Ryan Link to comment Share on other sites More sharing options...
JCviggen Posted August 23, 2005 Report Share Posted August 23, 2005 Also if i get EBC how far can i push the turbo and the engine.←Dont get an EBC. Its a) not necessary and looking from trouble on ME 7A chip will take care of everything. Link to comment Share on other sites More sharing options...
Che'_Moderator Posted August 23, 2005 Report Share Posted August 23, 2005 EBC is ok, just not with the OEM ECU. I think what he needs to do if givure out how much power he wants along with how much of a warrenty he wants. Link to comment Share on other sites More sharing options...
nick S60 R Posted August 24, 2005 Author Report Share Posted August 24, 2005 EBC is ok, just not with the OEM ECU. I think what he needs to do if givure out how much power he wants along with how much of a warrenty he wants.←I'm only looking for some modest hp gain(35-50hp), and I definetly don't what to void my warrenty. Link to comment Share on other sites More sharing options...
Che'_Moderator Posted August 24, 2005 Report Share Posted August 24, 2005 I'm only looking for some modest hp gain(35-50hp), and I definetly don't what to void my warrenty.←I would stay away from the DP and EBC then. The ECU their not going to like either but its a lot harder to spot. Link to comment Share on other sites More sharing options...
Texas850Turbo Posted August 24, 2005 Report Share Posted August 24, 2005 Take a look at swedespeed's R forum. They have tons more stuff on S60Rs than Volvospeed, just as Volvospeed has tons more stuff on 850s than Swedespeed. Link to comment Share on other sites More sharing options...
Che'_Moderator Posted August 24, 2005 Report Share Posted August 24, 2005 Take a look at swedespeed's R forum. They have tons more stuff on S60Rs than Volvospeed, just as Volvospeed has tons more stuff on 850s than Swedespeed.←Yeah but they dont know what their doing. They just throw money and custom floor mats at the car and hope it goes faster, Link to comment Share on other sites More sharing options...
gdizzle Posted August 24, 2005 Report Share Posted August 24, 2005 check out johanns site, www.swededemon.com Link to comment Share on other sites More sharing options...
WhiteT5 Posted August 24, 2005 Report Share Posted August 24, 2005 Yeah but they dont know what their doing. They just throw money and custom floor mats at the car and hope it goes faster,←True. There are several companies out there w/ products made for the S60R. You may want to look at the TME cat-back exhaust system for a few ponies. Also, keep an eye on the proress of Chuck's S60R project car. From the previews we've been shown, it will re-define "fast" . Link to comment Share on other sites More sharing options...
Johann Posted August 24, 2005 Report Share Posted August 24, 2005 True. There are several companies out there w/ products made for the S60R. You may want to look at the TME cat-back exhaust system for a few ponies. Also, keep an eye on the proress of Chuck's S60R project car. From the previews we've been shown, it will re-define "fast" .←Now why do I have a feeling that this project isn't very representative for you average tune??? Reading the comments I think the Engstrom/BSR PPC is the solution. It gives the car a bit more push and a very nice throttle feel. It isn't the solution for flat out performance but it suits the need given the warranty thought. Link to comment Share on other sites More sharing options...
