SIAMBLUE Posted April 27, 2004 Report Share Posted April 27, 2004 Hi I need some advice,I have a S70 T5,and also have a K&N panel filter with a Rica remap,taking it upto at least 280 hp,What i need to know,will or could i damage the car by running a boost sciences reliaboost MBC?as it has a small bleed hole,and T5s are supposed to run closed loop,so i have been told,also with the MBC what setting should it be set at?as the remap is taking it to 14.9 psi,with 98 ron fuel,hope to hear your views Gary. Link to comment Share on other sites More sharing options...
turbor850 Posted April 27, 2004 Report Share Posted April 27, 2004 Hey Gary, most of us on the board either go with TurboXS boost controller or a Dawes Devices. But you could go reliaboost if you like, as long as it is ball and spring type! Just set the MBC to what the current boost is now and you should be fine. Link to comment Share on other sites More sharing options...
SIAMBLUE Posted April 28, 2004 Author Report Share Posted April 28, 2004 Hi thanks for your reply,It is the spring and ball type,so will go ahead with that mod then,thanks again Gary Link to comment Share on other sites More sharing options...
turbor850 Posted April 28, 2004 Report Share Posted April 28, 2004 Make sure you have a boost guage and don't go too high with that boost. Link to comment Share on other sites More sharing options...
