kenk Posted August 30, 2005 Report Share Posted August 30, 2005 The dealer called and said they do not recommend machining the flywheel when doing a clutch job. That doesnt make sense to me, said they talked to a volvo engineer and said it causes problems if its machined. I really dont know, i have never heard of putting the flywheel back as is. Never. So what should I do? I could have the flywheel replaced at $500, that seems insane though, is there any technical reason why a flywheel should not be machined? help!!update: talked to the master tech there,Volvo HQ argument (dealer/mech called to get info). If you machine the flywheel, it could warp, and when its thinner it also will reduce the pressure that that pressure plate can exert..... makes sensemy thoughts: But if you dont machine it any imperfections will start cutting / wearing the new clutch disk. After 185,000 miles my flywheel cant be prestine. master tech's thoughts recomendations. If it was his car, hed replace the whole flywheel. Link to comment Share on other sites More sharing options...
Guest DougK Posted August 30, 2005 Report Share Posted August 30, 2005 Surface it or take weight off of it.Long as they dont interfere with the ring around the outside, surfacing it is a normal deal. If its a dual mass flywheel then you gots to buy a new one. Link to comment Share on other sites More sharing options...
kenk Posted August 31, 2005 Author Report Share Posted August 31, 2005 Yea, so they would not machine it. Ended up just replacing it. At least I know that it wont go out again for a long long time. Link to comment Share on other sites More sharing options...
