Playboy Posted September 4, 2005 Report Share Posted September 4, 2005 I've been watching my boost guage lately and when I put the peddle to the floor I'm not approaching 15 psi boost like my chip is setup to hit. I'm only hitting 12 or so for a second before going back down to 9-10 psi. I checked the vac tree near the throttle body and everything seems to be fine there. I don't know where else I would have a leak that could cause me to loose 3-5psi of boost. Anyone have any suggestions?-Ryan Link to comment Share on other sites More sharing options...
ToxicLemonade Posted September 4, 2005 Report Share Posted September 4, 2005 do you have a down pipe and exhuast? Link to comment Share on other sites More sharing options...
Playboy Posted September 4, 2005 Author Report Share Posted September 4, 2005 do you have a down pipe and exhuast?←yup and intake and chip.-Ryan Link to comment Share on other sites More sharing options...
ToxicLemonade Posted September 4, 2005 Report Share Posted September 4, 2005 yup and intake and chip.-Ryan←hmmm, my guess was that if you didnt have an intake and exhaust that you were just outflowing your exhaust. my guess now would be that you have a crack somewhere in a hose and it only opens up at higher PSI. time to revert back to replacing all the lines. -Ryan Link to comment Share on other sites More sharing options...
T5BRICK Posted September 4, 2005 Report Share Posted September 4, 2005 stage 0? check all of your vacuum lines and turbo hoses. also, a failing MAF can limit boost. Link to comment Share on other sites More sharing options...
Playboy Posted September 4, 2005 Author Report Share Posted September 4, 2005 stage 0? check all of your vacuum lines and turbo hoses. also, a failing MAF can limit boost.←are all the vac lines hard to replace?how do I know that I have a failing MAF sensor?-Ryan Link to comment Share on other sites More sharing options...
JoshV70 Posted September 4, 2005 Report Share Posted September 4, 2005 It could be the heat. I've noticed that. Yesterday afternoon I could only boost 11 psi. I went out again yesterday night, and I was boosting 16 psi without a problem. Link to comment Share on other sites More sharing options...
rikardsundelin Posted September 4, 2005 Report Share Posted September 4, 2005 I've been watching my boost guage lately and when I put the peddle to the floor I'm not approaching 15 psi boost like my chip is setup to hit. I'm only hitting 12 or so for a second before going back down to 9-10 psi. I checked the vac tree near the throttle body and everything seems to be fine there. I don't know where else I would have a leak that could cause me to loose 3-5psi of boost. Anyone have any suggestions?-Ryan←The boost drops because your turbo cant hold boost at high rpms. Unless you upgraded your turbo of course Check for leaks :excl: Link to comment Share on other sites More sharing options...
Noahkk19 Posted September 4, 2005 Report Share Posted September 4, 2005 my money is betting on a boost leak...a small one...check all the turbo hoses...its probably a leak that only comes under boost, so it'd be very hard to findSAMCO saves you from ever making a thread like this again Link to comment Share on other sites More sharing options...
ToxicLemonade Posted September 4, 2005 Report Share Posted September 4, 2005 The boost drops because your turbo cant hold boost at high rpms. Unless you upgraded your turbo of course Check for leaks ←not true, a 15g can hold 14-15psi. mine does. check the intercooler piping, could have a crack in it. Link to comment Share on other sites More sharing options...
T5BRICK Posted September 5, 2005 Report Share Posted September 5, 2005 are all the vac lines hard to replace?no, it only took me about 30 minutes to replace all of mine.how do I know that I have a failing MAF sensor?-Ryan←eventually i started getting CELs that related to the MAF. before that happend i would notice a tiny hesitation while i was on the freeway and sometimes while accelerating from a stop. Link to comment Share on other sites More sharing options...
Volvoson Posted September 5, 2005 Report Share Posted September 5, 2005 Stage 0!! I am losing some boost somewhere sometimes (it's not constant ) though...Once you check the vac/boost lines, check your BCS, it could be leaking, maybe? Link to comment Share on other sites More sharing options...
T5BRICK Posted September 5, 2005 Report Share Posted September 5, 2005 Stage 0!! I am losing some boost somewhere sometimes (it's not constant ) though...Once you check the vac/boost lines, check your BCS, it could be leaking, maybe?←how much boost Carson? i hit a solid 10PSI, fade to 7, and build to 10 again. i'm pretty sure i've just got a leak in my turbo hoses. Link to comment Share on other sites More sharing options...
Volvoson Posted September 5, 2005 Report Share Posted September 5, 2005 how much boost Carson? i hit a solid 10PSI, fade to 7, and build to 10 again. i'm pretty sure i've just got a leak in my turbo hoses.←I get spikes up to 15psi, but hold anywhere from 12-14psi while driving. I did a higher speed run (freeway entrance) up to 80ish at WOT, I noticed that in 3rd gear I would hold boost better then I would in 1st and 2nd gears... Link to comment Share on other sites More sharing options...
LeKid Posted September 5, 2005 Report Share Posted September 5, 2005 I saw Silicone Turbo piping available (like Samco) for I/C but where vac/boost lines can be bought? I mean the small ones (5, 7mm) going to wastegate, solenoid valve ...Is it available in lenght of X feet and you cut it to your needs? Link to comment Share on other sites More sharing options...
