parker2520 Posted September 8, 2005 Report Share Posted September 8, 2005 Can anyone help me with this?(Evap Emmissions System Valve) I changed the gas cap but still get the code. Anyone? Thanks...00XC Turbo Link to comment Share on other sites More sharing options...
Bay13 Posted September 8, 2005 Report Share Posted September 8, 2005 I'm not real familiar with the P codes but I'll guess. The most common problem with the evap system is the Canister Purge Valve (AKA evap valve). I'd suspect that first. You can test the valve with a hand held vacuum pump, the valve should hold vacuum on both connections, it usually doesn't. Link to comment Share on other sites More sharing options...
MrWinkey Posted September 8, 2005 Report Share Posted September 8, 2005 Check your small hoses at the canister under the car...one is probably torn...that is a very small evap leak. Link to comment Share on other sites More sharing options...
Guest Guest_parker2520_* Posted September 9, 2005 Report Share Posted September 9, 2005 Thank you for the info... Link to comment Share on other sites More sharing options...
2005V70R Posted September 13, 2005 Report Share Posted September 13, 2005 Canister Purge (EVAP) Valve fixed mine Link to comment Share on other sites More sharing options...
parker2520 Posted September 14, 2005 Author Report Share Posted September 14, 2005 Is the purge valve available from other than Volvo? Link to comment Share on other sites More sharing options...
Bay13 Posted September 14, 2005 Report Share Posted September 14, 2005 If you mean other than an Volvo dealer, yes.http://www.FCPgroton.comIf you don't find it on the site give them a call. Link to comment Share on other sites More sharing options...
parker2520 Posted September 14, 2005 Author Report Share Posted September 14, 2005 Groton, of course. Thanks much..... Link to comment Share on other sites More sharing options...
