vinopa30 Posted September 10, 2005 Report Share Posted September 10, 2005 '99 S70 100kmi NA 5spdAfter accelerating then letting in the clutch (allowing the needle to return to idle position) my idle drops to 500rpm then bounces between 500-1000 for about 30 seconds. Sometimes it actually stalls. It causes a lot of vibration at that low of an RPM and I don't want my engine mounts messed up. '99 S70 = $hitty electroinc throttle body. Could the air mass meter cause such a problem? Link to comment Share on other sites More sharing options...
gdizzle Posted September 10, 2005 Report Share Posted September 10, 2005 '99 S70 100kmi NA 5spdAfter accelerating then letting in the clutch (allowing the needle to return to idle position) my idle drops to 500rpm then bounces between 500-1000 for about 30 seconds. Sometimes it actually stalls. It causes a lot of vibration at that low of an RPM and I don't want my engine mounts messed up. '99 S70 = $hitty electroinc throttble body. Could the air mass meter cause such a problem?←I would give your throttle body a cleaning. To see if it's your maf, start the car up and unplug the MAF, if the idle smoothens out then well, there you go. Bad MAF will usually throw a CEL though.. Link to comment Share on other sites More sharing options...
MrWinkey Posted September 10, 2005 Report Share Posted September 10, 2005 Ya' I agree with Greg the whole problem is probably due to a dirty throttle housing. Link to comment Share on other sites More sharing options...
