Guest oli_boz Posted September 10, 2005 Report Share Posted September 10, 2005 hi guys, bought a volvo 1999 s40t se bout a year ago second hand,had a few problems,fuel regulator,spark plugs + pump replaced. Was running good for a while,but, every few days the lambda light and traction light switch on and stay on for a few days,took it to dealer they say its fine. Its using alot more fuel, has lost a lot of power and the oil seems to be burning quickly. Has anyone had similar problems.A friend of mine said to bypass the air flow sensor with a resistor(can't remember ohms) and fuel usage should drop and get increase on power.Anyone else heard of this? Link to comment Share on other sites More sharing options...
MrWinkey Posted September 10, 2005 Report Share Posted September 10, 2005 Really hard to say ?? Now if you had the codes read(scanned) and posted back with the codes retrieved perhaps we can help then. ;) Link to comment Share on other sites More sharing options...
Guest oli Posted September 13, 2005 Report Share Posted September 13, 2005 Really hard to say ?? Now if you had the codes read(scanned) and posted back with the codes retrieved perhaps we can help then. ← Link to comment Share on other sites More sharing options...
Guest oli_boz Posted September 13, 2005 Report Share Posted September 13, 2005 thanks,took it to the volvo service centre,as its being really hard to start and its stalled on me twice while turning a corner, the whole car switched off,all fault lights went on. They didn't give me a code just said that the fault is the air flow sensor needs replacing but the fault light is intermittant, guess i'll wait till my 90k service is due in about a month. Link to comment Share on other sites More sharing options...
