rp850 Posted September 16, 2005 Report Share Posted September 16, 2005 Where's the best place to hook up the hot lead of this adapter? I would think it needs to be switchable with the radio. Also, when I'm doing this splicing, do I need to disconnect the battery?Thanks! Link to comment Share on other sites More sharing options...
Bing_0 Posted September 17, 2005 Report Share Posted September 17, 2005 dpends on hwat it draws, if not a lot, and you need it to come on with the radio, you can tap into the radio harness.but the safest way is to put it into the ignitional main harness under the steering column and tape into ACC or ignition...but you gotta take off hte knee bolster and all that good ness.i would also recommend putting a inline fuse on it no matter what b Link to comment Share on other sites More sharing options...
rp850 Posted September 17, 2005 Author Report Share Posted September 17, 2005 Thanks for your reply. The VOLALP is actually an adapter from an Alpine CD changer to the CD port on my SC-811 radio. The adapter already has the hot lead with an inline fuse. Sure would be easier to patch into the radio harness...dpends on hwat it draws, if not a lot, and you need it to come on with the radio, you can tap into the radio harness.but the safest way is to put it into the ignitional main harness under the steering column and tape into ACC or ignition...but you gotta take off hte knee bolster and all that good ness.i would also recommend putting a inline fuse on it no matter what b Link to comment Share on other sites More sharing options...
Bing_0 Posted September 17, 2005 Report Share Posted September 17, 2005 then yup, go to the radio harenss for power should be fine :) Link to comment Share on other sites More sharing options...
rp850 Posted September 17, 2005 Author Report Share Posted September 17, 2005 Cool. Hey, thanks a lot! So looking at the radio connector diagram I'll be splicing into 13A on the A plug of the radio harness (yellow wire).then yup, go to the radio harenss for power should be fine Link to comment Share on other sites More sharing options...
