Guest Guest_Phil_* Posted September 18, 2005 Report Share Posted September 18, 2005 Does anybody know what aftermarket ATF fluid the S60 2.4T uses? I'm thinking of replacing. I have 63K on the car. Has anybody tried synthetic oil? Is it a good substitute? Any help would be appreciated. Also, is there a tranny drain plug on this car. Thanks. Link to comment Share on other sites More sharing options...
Guest Guest Posted September 18, 2005 Report Share Posted September 18, 2005 The OEM fluid is Volvo transmission oil 1161540- 8. This is the same as Mobil ATF 3309 which can probably be purchased by the case from a Mobil distributor. Flushing is more complicated than pulling a drain plug. For example, check out the following thread: http://www.volvoxc.com/forums/showthread.p...ight=mobil+3309Bill Link to comment Share on other sites More sharing options...
