Guest Guest_2step_* Posted September 20, 2005 Report Share Posted September 20, 2005 Ever since I changed the front brakes ('01 XC) I have a clanging noise when going over or hitting a bump, does anyone have a pic of how the clips or anti rattle clips go on, I may have them on wrong. Thanks Link to comment Share on other sites More sharing options...
dynakev Posted September 20, 2005 Report Share Posted September 20, 2005 Ever since I changed the front brakes ('01 XC) I have a clanging noise when going over or hitting a bump, does anyone have a pic of how the clips or anti rattle clips go on, I may have them on wrong. ThanksDid you use OEM pads? I had a set of aftermarket pads on an S80, and it seemed like there was a little bit of fore and aft sloppiness with the pads moving in the caliper. OEM pads fixed the problem. Link to comment Share on other sites More sharing options...
jbuck Posted September 21, 2005 Report Share Posted September 21, 2005 Ever since I changed the front brakes ('01 XC) I have a clanging noise when going over or hitting a bump, does anyone have a pic of how the clips or anti rattle clips go on, I may have them on wrong. ThanksI think you're right it might be the clips. If they went on easily they're probably not on right. :P Link to comment Share on other sites More sharing options...
MrWinkey Posted September 21, 2005 Report Share Posted September 21, 2005 I'm not sure as to how you could have the clips on wrong? You took them off didn't you?....I'm more inclined to think you used aftermarket pads as previously stated. If you did they can and will rattle as the 3 prong clip on the inner pad usually does not fit tightly into the caliper piston? Link to comment Share on other sites More sharing options...
