SIAMBLUE Posted May 1, 2004 Report Share Posted May 1, 2004 Hi Folks,Just a quiery here on a Boost sciences MBC,I have this fitted about a month ago,with a atmospheric Dump valve and blanking plate over the recirc valve,With the MBC i bypassed the Boost solenoid,as in the instructions to do,But after about a week of running it went into limp mode,and i have now found out i have damaged theMAF,MAF is now replaced,I have now removed the Dump valve and blanking plate,as i thought this might be at fault,The car has now been remapped with a Rica mapping,and the recirc valve is standard,I don't want to fit the dump valve but want to refit the MBC,shall i fit it as before or shall i just put it into the actuator line only?and retain the Boost solenoid?any help would be most appreciated,Gary. Link to comment Share on other sites More sharing options...
freeskier8585 Posted May 1, 2004 Report Share Posted May 1, 2004 sounds like a coincidence, the maf shouldnt be affected by the mbc.... Link to comment Share on other sites More sharing options...
SIAMBLUE Posted May 1, 2004 Author Report Share Posted May 1, 2004 Hi That's what i thought,But didn't want to make the same mistake,if it was a problem,So do i fit the MBC into the actuator line and retain the Boost Solenoid,or fit it as instructions and bypass it?as it is mapped now,and i don't want to cause any heatsoak, Link to comment Share on other sites More sharing options...
