mikie Posted September 22, 2005 Report Share Posted September 22, 2005 Okay I did something really stupid. I wanted to clean my throttle body, I've done this before but this time I figured why not clean all connectors and what not. So I decided that I was going to remove the black plastic plate which have 4 srcews facing towards you as your looking at the front of the car. So I removed the screws and the thing was bloody tight, I tried as gentle as possible to pull it out...well I pulled too hard and the two wires that are soldered to two connectors broke away. I got all sorts of codes (lot's) tried to clear them and would not clear obviously. So since I dont have anything to solder them back and just used extra wire to connect everything back. This definatly does not look like it would last very long but at least I was able to clear all codes and engine is running fine. So what should I do, get a machine to solder these wires, go somewhere and get it done or am I going to be needing a new throttle body?Thanks,MikeI just read that thread about not posting anything about Thottle Bodies, I hope this one is alright...if not sorry. Link to comment Share on other sites More sharing options...
gdizzle Posted September 22, 2005 Report Share Posted September 22, 2005 Okay I did something really stupid. I wanted to clean my throttle body, I've done this before but this time I figured why not clean all connectors and what not. So I decided that I was going to remove the black plastic plate which have 4 srcews facing towards you as your looking at the front of the car. So I removed the screws and the thing was bloody tight, I tried as gentle as possible to pull it out...well I pulled too hard and the two wires that are soldered to two connectors broke away. I got all sorts of codes (lot's) tried to clear them and would not clear obviously. So since I dont have anything to solder them back and just used extra wire to connect everything back. This definatly does not look like it would last very long but at least I was able to clear all codes and engine is running fine. So what should I do, get a machine to solder these wires, go somewhere and get it done or am I going to be needing a new throttle body?Thanks,MikeI just read that thread about not posting anything about Thottle Bodies, I hope this one is alright...if not sorry.No, this post is fine and you're screwed. Time for a new TB. We don't want any political threads about the ETM issue in this sectoin, if you want to talk about that crap, take it to OT and talk about it all you want. Don't know what is so hard to understand about this.... :rolleyes: Link to comment Share on other sites More sharing options...
mikie Posted September 22, 2005 Author Report Share Posted September 22, 2005 No, this post is fine and you're screwed.But the car is runing fine...I kinda know that I'm screwed...lolHowever there is a possibility that everything will be fine right? Link to comment Share on other sites More sharing options...
Bay13 Posted September 22, 2005 Report Share Posted September 22, 2005 However there is a possibility that everything will be fine right?I don't think so. If you pull off getting things back together and no codes returning, then you are one luck man. Link to comment Share on other sites More sharing options...
