rodrigo Posted September 30, 2005 Report Share Posted September 30, 2005 I have been using Castrol motor oil since I bought my first car (7 years ago). When my old Jetta reached 160,000 miles I switched it to Castrol High Mileage (went to 197,000), and it was fine...didn't really notice a difference. So, naturally, my Volvo's have had Castrol...the regular 10/30 in the previous 940, and I used 5/30 in the current 850 LPT.Before driving down to Maryland last Friday, I did an oil change...Mobil 1 High Mileage 5/40. The car had 147,000 miles, no oil consumption, and oil and oil filter is changed every 3000 miles.Here's what I noticed: . no more valve tappy noise for .05 sec on start up in the morning.. boost gauge reads +4 in Hg at iddle when at operating temp.Pretty cool! Wasn't expecting to make that much of a difference. What you guys think...normal? Link to comment Share on other sites More sharing options...
WhiteT5 Posted September 30, 2005 Report Share Posted September 30, 2005 . boost gauge reads +4 in Hg at iddle when at operating temp.Pretty cool! Wasn't expecting to make that much of a difference. What you guys think...normal?I think you have a vacuum leak ;) Link to comment Share on other sites More sharing options...
PorBleemo Posted September 30, 2005 Report Share Posted September 30, 2005 I think you have a boost leak Yeah, less vacuum is not better for these cars. Unless it rose with the A/C on. Link to comment Share on other sites More sharing options...
rodrigo Posted September 30, 2005 Author Report Share Posted September 30, 2005 Yeah, less vacuum is not better for these cars. Unless it rose with the A/C on.I think I worded it wrong...the boost gauge used to read 20-21 in Hg. with the CatrolNow it reads 23-24 in Hg. with the castrol.when the A/C is on, it always goes -2 in HgNow, with the Mobil, it iddles cold at 20 or so, and after warming up I'll drive around for a bit and while rolling, I'll let off the gas and it will read 23-24 in HgIs that symptoms of a vaccuum leak? I'll have to perform a search. :blink: Link to comment Share on other sites More sharing options...
WhiteT5 Posted September 30, 2005 Report Share Posted September 30, 2005 I think I worded it wrong...the boost gauge used to read 20-21 in Hg. with the CatrolNow it reads 23-24 in Hg. with the castrol.when the A/C is on, it always goes -2 in HgNow, with the Mobil, it iddles cold at 20 or so, and after warming up I'll drive around for a bit and while rolling, I'll let off the gas and it will read 23-24 in HgIs that symptoms of a vaccuum leak? I'll have to perform a search. No, it was just worded a bit oddly in the first post. You're right on target. Link to comment Share on other sites More sharing options...
pete0r Posted September 30, 2005 Report Share Posted September 30, 2005 i'm scared to put mobil 1 in my car with 135k of dino.. i go through about half a quart between changes Link to comment Share on other sites More sharing options...
Zappo Posted September 30, 2005 Report Share Posted September 30, 2005 i'm scared to put mobil 1 in my car with 135k of dino.. i go through about half a quart between changesI have 133k on my car and I have been running Mobil 1 synthetic for the past 6000 miles. I don't have any increased oil usage. Link to comment Share on other sites More sharing options...
RWagin Posted September 30, 2005 Report Share Posted September 30, 2005 Don't forget about the possibility of a RMS leak developing after the change... Link to comment Share on other sites More sharing options...
pete0r Posted September 30, 2005 Report Share Posted September 30, 2005 Don't forget about the possibility of a RMS leak developing after the change...ding dingexactly Link to comment Share on other sites More sharing options...
rodrigo Posted September 30, 2005 Author Report Share Posted September 30, 2005 ding dingexactlysOOper nOOb question # 387-3.7-R: whats an RMS leak?<edit> Rear Main Seal? The car does not leak anything at all right now. Why would not leak before the oil change and leak after the oil change ? Link to comment Share on other sites More sharing options...
the underlørd Posted September 30, 2005 Report Share Posted September 30, 2005 sOOper nOOb question # 387-3.7-R: whats an RMS leak?<edit> Rear Main Seal? The car does not leak anything at all right now. Why would not leak before the oil change and leak after the oil change ?switching to a synthetic at a high mileage can cause leaks... Link to comment Share on other sites More sharing options...
maiku Posted September 30, 2005 Report Share Posted September 30, 2005 Rear Main Seal is BAAAAADmy 850 had that problem and it was $$$ to fixdon't know about the S70 yet *knock on wood* Link to comment Share on other sites More sharing options...
rodrigo Posted September 30, 2005 Author Report Share Posted September 30, 2005 Rear Main Seal is BAAAAADmy 850 had that problem and it was $$$ to fixdon't know about the S70 yet *knock on wood*switching to a synthetic at a high mileage can cause leaks...But if the RMS is leaky, then there would be oil drips on the ground underneath the car, right?My parking spot is pretty clean. Should I just return to the regular Castrol I was using before on the oil change? You guys are getting me worried :ph34r: Link to comment Share on other sites More sharing options...
maiku Posted September 30, 2005 Report Share Posted September 30, 2005 changing dino oil regularly should be finesynthetic is just good for extreme engine temps, and longer oil change life Link to comment Share on other sites More sharing options...
rodrigo Posted September 30, 2005 Author Report Share Posted September 30, 2005 I change my oil every 3000 with out fail. Almost all the cars I have had have gone to 200,000 miles or very close.whats dino oil? :huh: Link to comment Share on other sites More sharing options...
