benson304 Posted May 5, 2004 Report Share Posted May 5, 2004 Where is the passthru on the firewall located? Pictures if possible.Also, where do the wires go from the head unit to the back, I know that they go on the opposite side of the car from the amp wire in the same fashion, but where do they end up after they are connected to the deck?It may seem like common sense stuff, but I just want to be sure. My main thing is the firewall passthru, I think I have the right idea about the second question though. Link to comment Share on other sites More sharing options...
850 Stylzz Posted May 5, 2004 Report Share Posted May 5, 2004 Firewall pass-thru is located under the dash just above the hood release. You will see a thing with like 3 "nipples" coming off of it and some wires coming though as well. On my recent build, this was definitely one of the hardest parts about the install. I was running 4 gauge power wire through (actually behind the plug--no way you could fit one through the nipples) the wall and out the loom in the engine bay. Im not sure if the loom is standard or the result of some elec work done by the previous owner, but it was an absolute B!TCH to get through. I snagged that wire in the inside ribs so many times. Eventually cut the loom and taped it up really good b/c there was NO WAY to get the wire around one of the bends. you can find pretty good pics in the reference section under sub/amp install. Link to comment Share on other sites More sharing options...
Che'_Moderator Posted May 5, 2004 Report Share Posted May 5, 2004 Use the site Luke Link to comment Share on other sites More sharing options...
benson304 Posted May 5, 2004 Author Report Share Posted May 5, 2004 I actually looked right after to see if Anthony's guide was on the site, cause his site is down, and I found that And who's Luke? :rolleyes: Link to comment Share on other sites More sharing options...
turbobrick Posted May 5, 2004 Report Share Posted May 5, 2004 .... help me obiwan.. you're my only hope :ph34r: Link to comment Share on other sites More sharing options...
850 Stylzz Posted May 5, 2004 Report Share Posted May 5, 2004 And who's Luke? I hope that rolling eyes indicates sarcasm...cause otherwise Im gonna shove a wookie up your A $ $ Link to comment Share on other sites More sharing options...
DanielSFbay Posted May 5, 2004 Report Share Posted May 5, 2004 Link to comment Share on other sites More sharing options...
benson304 Posted May 5, 2004 Author Report Share Posted May 5, 2004 Of course it's a sarcastic remark.I went out and found that passthru, after that it seems simple. Link to comment Share on other sites More sharing options...
Jozone Posted May 6, 2004 Report Share Posted May 6, 2004 i ended up having to cut the nipple... simply wouldn't take the 4 guage... if you're running 8 you should be okay with a little effort. Link to comment Share on other sites More sharing options...
Jamaica2G Posted May 8, 2004 Report Share Posted May 8, 2004 I just pulled off the whole ends with the three nipples. They were on both sides of the plastic pipe... the 4 GA wire just barely fit - took about 15 min of wiggling etc to get it through. its a better position that where I had it before - it was going around by the front door; I'm sure it was an accident hazard. to get to it from the interior, pull off the knee protector on the driver's side and start digging through wires and you'll see the lil pipe.Adrian Link to comment Share on other sites More sharing options...
benson304 Posted May 9, 2004 Author Report Share Posted May 9, 2004 Yeah I got it all installed, wasn't too hard, hardest part was the wire through the passthru, then I realized I hadn't taken off one of the protectors. I am still waiting on the box, which will be here on Wens. then we'll see what this baby can really do. Link to comment Share on other sites More sharing options...
