gr8gatzby Posted October 22, 2005 Report Share Posted October 22, 2005 removed the front cover(2 torx) thinking that the plugs were underneath, i removed the rail held down by two bolts, and i dont know what in hades those 5 rubber dealios are, but i removed them. hey that doesnt look like a spark plug!injectors perhaps?so now i'm removing the large cover on the rear top of the block. i've only one torx remaining, but it's blocked by the turbo hose. attempting to remove the rubo pipe, but i cant get to the bolt that holds it in place to the block. what am i doing wrong here.... Link to comment Share on other sites More sharing options...
Johann Posted October 22, 2005 Report Share Posted October 22, 2005 removed the front cover(2 torx) thinking that the plugs were underneath, i removed the rail held down by two bolts, and i dont know what in hades those 5 rubber dealios are, but i removed them. hey that doesnt look like a spark plug!injectors perhaps?so now i'm removing the large cover on the rear top of the block. i've only one torx remaining, but it's blocked by the turbo hose. attempting to remove the rubo pipe, but i cant get to the bolt that holds it in place to the block. what am i doing wrong here....Yes, remove injectors and install the new plugs.Probably a 25 bhp gain minimum.. :josh: Link to comment Share on other sites More sharing options...
gr8gatzby Posted October 22, 2005 Author Report Share Posted October 22, 2005 Yes, remove injectors and install the new plugs.Probably a 25 bhp gain minimum.. why is this OT? Link to comment Share on other sites More sharing options...
Johann Posted October 22, 2005 Report Share Posted October 22, 2005 Because it isn't maintenance. It is a review of stupidity and food for OT talk. Link to comment Share on other sites More sharing options...
gdizzle Posted October 22, 2005 Report Share Posted October 22, 2005 Because it isn't maintenance. It is a review of stupidity and food for OT talk. :lol: Link to comment Share on other sites More sharing options...
gr8gatzby Posted October 22, 2005 Author Report Share Posted October 22, 2005 as true as this may be. this is a post about how to remove the cover with teh turbo pipe in the way to get to the spark plugs. shall i repost? Link to comment Share on other sites More sharing options...
Che'_Moderator Posted October 22, 2005 Report Share Posted October 22, 2005 Just remove the torx and slide out the spark plug cover. Link to comment Share on other sites More sharing options...
BlackT5 Posted October 22, 2005 Report Share Posted October 22, 2005 You might have to remove the one bolt that holds the top IC pipe in place. This should give you enough room to get at the last torx. Link to comment Share on other sites More sharing options...
JCviggen Posted October 22, 2005 Report Share Posted October 22, 2005 Yes, remove injectors and install the new plugs.Probably a 25 bhp gain minimum..Careful though you might run a bit lean Link to comment Share on other sites More sharing options...
gr8gatzby Posted October 22, 2005 Author Report Share Posted October 22, 2005 Careful though you might run a bit leangot it all off, although i had to dislocate my thumb(this also works with handcuffs)to get around the turbo pipe, but all is well. Link to comment Share on other sites More sharing options...
