droot Posted November 1, 2005 Report Share Posted November 1, 2005 I have a 850t and I broke the hood release from inside the car, the wire snaped right were it hooks into the lever, i tried pulling it with plyers but it's not enough wire to hold on to.any suggestions?thanks droot Link to comment Share on other sites More sharing options...
Guest AlvinL Posted November 1, 2005 Report Share Posted November 1, 2005 Good vise grips instead of pliers? Link to comment Share on other sites More sharing options...
yangotang Posted November 1, 2005 Report Share Posted November 1, 2005 Are you sure the wire is broken or is the plastic broken?The wire should have a little nub at the very end which attaches to the lever itself; if it is indeed the lever that is broken you should be able to find a replacement for relatively cheap and be able to release the hood. Link to comment Share on other sites More sharing options...
droot Posted November 1, 2005 Author Report Share Posted November 1, 2005 I used a pair of vise grips but it wouldn't budge, could my hood be stuck some how?Good vise grips instead of pliers?ya that numb broke clean off the plastic is fine, which is funny I though the plastic would brake before the wire.Are you sure the wire is broken or is the plastic broken?The wire should have a little nub at the very end which attaches to the lever itself; if it is indeed the lever that is broken you should be able to find a replacement for relatively cheap and be able to release the hood. Link to comment Share on other sites More sharing options...
Guest AlvinL Posted November 1, 2005 Report Share Posted November 1, 2005 Get a couple of persons to help push down on each corner of the hood over the latch to take the weight off while you pull on whatever wire you have left. You might as well cut the sheathing off to make more wire available for pulling. Link to comment Share on other sites More sharing options...
