banksie312 Posted November 11, 2005 Report Share Posted November 11, 2005 i just took out my volvo 6 disc changer from my old car and was hoping to put it in my new onehowever, when i pulled out the HU, i found that there was a plug into the place for a cd changeri thought it was weird and turned on the carthey said that cds didnt work, so i tried the indash one and it worked fine, i tested the changer button on it, and it just said EEEE on itis there actually a cd changer and if so where would it be!its not in an obvoius spot for me to find, glovebox, trunk if there isnt one, then why is something plugged in and where do you suppose it might go?my it goes with the back speaker wires in the same direction they went on my 850, is there a cable hidden behind a panel somewhere?thanks Link to comment Share on other sites More sharing options...
the underlørd Posted November 11, 2005 Report Share Posted November 11, 2005 it's prewired.. my car has that too, and never had the changer. Link to comment Share on other sites More sharing options...
Serge Posted November 11, 2005 Report Share Posted November 11, 2005 The car is prewired for it but if it says "EEEE" that means it's not found. Link to comment Share on other sites More sharing options...
banksie312 Posted November 11, 2005 Author Report Share Posted November 11, 2005 ok coolsooo, wheres the wire for it go to? Link to comment Share on other sites More sharing options...
the underlørd Posted November 12, 2005 Report Share Posted November 12, 2005 ok coolsooo, wheres the wire for it go to?pull the cover to change the taillight bulb on the drivers side.. and then pull up the little flap ... it's buried in there somewhere. Link to comment Share on other sites More sharing options...
banksie312 Posted November 12, 2005 Author Report Share Posted November 12, 2005 thanks Link to comment Share on other sites More sharing options...
maiku Posted November 12, 2005 Report Share Posted November 12, 2005 my S70 has the cable toonearly all volvo HU's have the port for the cd changer Link to comment Share on other sites More sharing options...
banksie312 Posted November 12, 2005 Author Report Share Posted November 12, 2005 so i took out the drivers side lower taillight panel and looked, nothing, then i took out the drivers side floor panel in the trunk, nothingi dont know where it isi see that every wire is connected somehowdo i have to take off the drivers side wheel well panel? cause thats a lot of work or its a pain, or is it just a straight pull? Link to comment Share on other sites More sharing options...
the underlørd Posted November 12, 2005 Report Share Posted November 12, 2005 so i took out the drivers side lower taillight panel and looked, nothing, then i took out the drivers side floor panel in the trunk, nothingi dont know where it isi see that every wire is connected somehowdo i have to take off the drivers side wheel well panel? cause thats a lot of work or its a pain, or is it just a straight pull?trust me, it's there... there will be a plasitc power connector taped to the PIN connector. Link to comment Share on other sites More sharing options...
banksie312 Posted November 13, 2005 Author Report Share Posted November 13, 2005 trust me, it's there... there will be a plasitc power connector taped to the PIN connector.do you know which one? or is it just in one of them somewhere?and is it connected to anything or is the metal piece with the 2 connectors just hanging there? Link to comment Share on other sites More sharing options...
the underlørd Posted November 13, 2005 Report Share Posted November 13, 2005 do you know which one? or is it just in one of them somewhere?and is it connected to anything or is the metal piece with the 2 connectors just hanging there?its' on the drivers side, rear.. if you take the brake light cover off, and the lil quarterpanel cover off, you'll find it. Link to comment Share on other sites More sharing options...
SkyWriter Posted November 29, 2005 Report Share Posted November 29, 2005 its' on the drivers side, rear.. if you take the brake light cover off, and the lil quarterpanel cover off, you'll find it.I am on the hunt for this wiley cable as well, except my car is the 2001 S80. I have OEM 10 cd changer, and mounting bracket + HU 801. my eye's just get blurry looking in at all the unfamiliar wires there. Thanks!John Link to comment Share on other sites More sharing options...
the underlørd Posted November 29, 2005 Report Share Posted November 29, 2005 I am on the hunt for this wiley cable as well, except my car is the 2001 S80. I have OEM 10 cd changer, and mounting bracket + HU 801. my eye's just get blurry looking in at all the unfamiliar wires there. Thanks!JohnS80, i bet didn't come prewired? I was speaking to MK1 V70's. Link to comment Share on other sites More sharing options...
SkyWriter Posted November 29, 2005 Report Share Posted November 29, 2005 S80, i bet didn't come prewired?i don't know; that's why i'm asking. unfortunately 3 characters is the limit of the difference between all volvos and the minimum search symbol. I was speaking to MK1 V70's.indeed, such was the subtitle of the thread. i was hoping someone might know the answer for similarily nonplussed S80 owners. Link to comment Share on other sites More sharing options...
the underlørd Posted November 29, 2005 Report Share Posted November 29, 2005 i don't know; that's why i'm asking. unfortunately 3 characters is the limit of the difference between all volvos and the minimum search symbol.a search for S80*CD = this Link to comment Share on other sites More sharing options...
