biged30 Posted November 13, 2005 Report Share Posted November 13, 2005 Those that have installed playstaions, xboxs, or miscellanious electrical stuff I assume all of you used 12V to 110V current converters. How easy was it to install and has it caused any strain on the alternator or battery? I'm running a lot already with audio and video and I'm not necessarly set on putting in a game system, but I want to know for reference. Link to comment Share on other sites More sharing options...
Zappo Posted November 13, 2005 Report Share Posted November 13, 2005 Those that have installed playstaions, xboxs, or miscellanious electrical stuff I assume all of you used 12V to 110V current converters. How easy was it to install and has it caused any strain on the alternator or battery? I'm running a lot already with audio and video and I'm not necessarly set on putting in a game system, but I want to know for reference.So, you are going to be cranking 500 watts out of the stereo at the same time you are playing XBox? A game machine doesn't have an amp in it, so it won't be taking a lot of power to run. Link to comment Share on other sites More sharing options...
biged30 Posted November 13, 2005 Author Report Share Posted November 13, 2005 haha, naw probably wouldnt run the stereo at full blast while playing games. I have more than 500 watts pumping too. So essentually running a game system even off a voltage converter does no more drain than running any 12v device plugged into a cigarette lighter? Yeah it would be a fun little project to do, but I would have to figure out where to have the converter installed. Under the back seat? plus a place to have the game system and keep everything clean. I guess for now I can throw a PSP or for the old schol type I still ahve a game gear. Yes a game gear circa early 90s. Link to comment Share on other sites More sharing options...
Zappo Posted November 13, 2005 Report Share Posted November 13, 2005 If you plug in a 175 watt power inverter, but the game machine is only using 30, it only uses 30. Not sure what the game machines really use, but it can't be a lot.I have a small 175 watt inverter, but I haven't used it yet. Link to comment Share on other sites More sharing options...
yangotang Posted November 13, 2005 Report Share Posted November 13, 2005 I know for a fact that the PS2 that my friend had connected to his Mazda 5 was rated for 72W of power. He used a 400W inverter and was able to play loud music while playing PS2 on the stock battery.I believed he sourced the 400W inverter from Costco. Link to comment Share on other sites More sharing options...
biged30 Posted November 13, 2005 Author Report Share Posted November 13, 2005 Costco huh? I love me some Costco, unfortunately when I got out here to lovely Oklahoma I came to realize they dont have COstco out here. Maybe when I go to Indianapolis for a weekend in December I'll make a trip over to Costco. Did your buddy's inverter come with plenty of wire? Cause my idea for placement would require a ton of wire, bout the same amount for an amp. Link to comment Share on other sites More sharing options...
yangotang Posted November 13, 2005 Report Share Posted November 13, 2005 Costco huh? I love me some Costco, unfortunately when I got out here to lovely Oklahoma I came to realize they dont have COstco out here. Maybe when I go to Indianapolis for a weekend in December I'll make a trip over to Costco. Did your buddy's inverter come with plenty of wire? Cause my idea for placement would require a ton of wire, bout the same amount for an amp.I think a little bit of custom wiring was needed; i'm not totally sure because he had a shop do a custom install for him into the dashboard.Costco huh? I love me some Costco, unfortunately when I got out here to lovely Oklahoma I came to realize they dont have COstco out here. Maybe when I go to Indianapolis for a weekend in December I'll make a trip over to Costco. Did your buddy's inverter come with plenty of wire? Cause my idea for placement would require a ton of wire, bout the same amount for an amp.I think a little bit of custom wiring was needed; i'm not totally sure because he had a shop do a custom integration of the inverter into the glove compartment Link to comment Share on other sites More sharing options...
biged30 Posted November 13, 2005 Author Report Share Posted November 13, 2005 yeah I dont know if you saw my other post I started showing my system. Unfortunately the glowbox is not an option now. NOt even tucked behind the glovebox. You should see how tight of a fit behind there it is.Yeah if custom wiring is needed I'll probably leave that to a shop so I can get some warranty on the job. Although I'm pretty good with wiring, I would ahte to have a bad wiring job on an inverter turn ugly. PLus I woudlnt want to fry a game system. Link to comment Share on other sites More sharing options...
banksie312 Posted November 14, 2005 Report Share Posted November 14, 2005 for the old schol type I still ahve a game gear. Yes a game gear circa early 90s.game gear is the way to go thanks for posting this cause i was about to ask the same questions Link to comment Share on other sites More sharing options...
biged30 Posted November 14, 2005 Author Report Share Posted November 14, 2005 better yet...I still have the tv tuner for it...doesnt work that great...looks more like a hand held tv you see people bring to football or baseball games...but still...classic Link to comment Share on other sites More sharing options...
