850 Stylzz Posted November 18, 2005 Report Share Posted November 18, 2005 ok, so I already posted about the sub I picked up for cheap off of ebay. See it hereNow I need tp pick up another amp to drive it. I think I can get a Pioneer GM3100T for pretty cheap, but Im not sure it will be powerful enough. Opinions?ps. The pioneer says its max RMS at 4 ohms is 150 watts. Link to comment Share on other sites More sharing options...
Bing_0 Posted November 18, 2005 Report Share Posted November 18, 2005 it will b efine, unless youa re looking for a ton of bass, but if you are looking for a ton of bass, you shouldnt be looking at sony xplod subs and a small ampbut othe wise, that amp will be perfectly fine i hav a 400 watt rated sub and only sending 190 watts to it b Link to comment Share on other sites More sharing options...
850 Stylzz Posted November 18, 2005 Author Report Share Posted November 18, 2005 it will b efine, unless youa re looking for a ton of bass, but if you are looking for a ton of bass, you shouldnt be looking at sony xplod subs and a small ampbut othe wise, that amp will be perfectly fine i hav a 400 watt rated sub and only sending 190 watts to it bThanks for the quick reply Bing. As I look at that amp forther though, I see that it only allows for one X-over frequency; 80Hz. Im not sure I like that. I think Id much rather cross it higher, like at 120 or 150. Is this a bad idea? To have a sub reach that high? Im just worried that I'll be missing out on a substantial frequency range between the 80 HZ and what the rest of my speakers can effectively handle.Or, should I pick it up, and then just purchase a seperate X-over to go pre-amp? Link to comment Share on other sites More sharing options...
