Am I Going To Find Any Surprises
8G5L0T
Hey whats up I am knew to the forums. I have a red 1997 850 GLT. IT has premium sound. I am about to put a system in it. 2 12 Rockford Fosgate Punch Level 2s 4ohm subs, alpine 9847 deck, 5 1/4 kennwood components speakers,a Kenwood KAC-9102D amp, and a sealed box. Is there anything that i could run into that could cause me some trouble?
get a METRA wiring harness for the HU, and a METRA lower DIN pocket, and you're golden.
First off...welcome to the board! You should be fine as long as you know what you're doing. You may have to help make those speakers fit, but then again many people have had different experiences with what will fit easily. You may want to check out the firewall passthrough thread too if you don't know how to run the power. Good luck.
-MIKE D
Thanks guys. Hey i am only 16 and this is my first system intallation. My dad is helping me as well. But i have this amp as mentioned with these specs:Amplifier Type: Mono
RMS Power: 500W x 1 @ 4 ohms
THD at 4-Ohm RMS Power: 0.08 %
RMS Power: 850W x 1 @ 2 ohms
Speaker Level Inputs: Yes
Preamp Outputs: Yes
Built-In Crossovers: LP
Bass Boost: 0 - 18 dB
Frequency Response: 5-200 Hz
Signal to Noise Ratio: 100 dB
Fuse Rating: n/a
This amp is going to power my 2 subs right. I want them to hit. And what type of wiring should i use. Or wiring kit. And the 2 small single tweeters that come with my component speakers are going to fit in the compartment where my original tweeters are correct?
Links
Component Speakers
My subs
Amp
You should be set...As for the tweeters, I cut some ABS plastic to custom fit back in the stock location...
Worked quite well. Id prolly just go with a 4guage amp kit since 8 guage is too weak for my liking. You should be fine tho, installs are pretty easy as long as you take your time. Good luck again.
-MIKE D
