8G5L0T Posted November 19, 2005 Report Share Posted November 19, 2005 I am just wondering if i should be concerned with a wierd sound coming from my brakes. They squeek whenever i brake for the first time after it has been sitting off for a few hours that goes away after a 1 or 2 breaks. The major concern is that whenver i accelerate really fast and brake hard my front left brake seems to be rubbing up agains the pad or something. It sounds like metal on metal. It s only the front left wheel. Is this a big worry. Link to comment Share on other sites More sharing options...
yangotang Posted November 19, 2005 Report Share Posted November 19, 2005 I am just wondering if i should be concerned with a wierd sound coming from my brakes. They squeek whenever i brake for the first time after it has been sitting off for a few hours that goes away after a 1 or 2 breaks. The major concern is that whenver i accelerate really fast and brake hard my front left brake seems to be rubbing up agains the pad or something. It sounds like metal on metal. It s only the front left wheel. Is this a big worry.How many mm are left on the pads? What kind of pads/rotors are you using? Are they OEM? Link to comment Share on other sites More sharing options...
8G5L0T Posted November 20, 2005 Author Report Share Posted November 20, 2005 Hey, i have no idea i think they are stock.How do you check? These brakes are starting to get on my nerves. Link to comment Share on other sites More sharing options...
Guest Guest_Pete_* Posted November 20, 2005 Report Share Posted November 20, 2005 I've got a 97 GLT too. Just did the brakes at about 55k and yes I would check the wear left on the pads. That's your first check.I ended up with Brembo rotors and Mintex pads and the combo seems to work fine. I've also heard that the Volvo pads work well with the Brembo's also. Good luck. Link to comment Share on other sites More sharing options...
