whatme Posted November 22, 2005 Report Share Posted November 22, 2005 How high should the boost hit on the stock turbo gauge in my 850?? It seems like it is strugglin to hit above 1/2 bar at WOT....that doesnt seem right....does it? <_< Link to comment Share on other sites More sharing options...
yangotang Posted November 22, 2005 Report Share Posted November 22, 2005 How high should the boost hit on the stock turbo gauge in my 850?? It seems like it is strugglin to hit above 1/2 bar at WOT....that doesnt seem right....does it? It should reach 2/3 on the stocker during full WOT at high RPM; however, I wouldn't trust that gauge to be accurate. You should really hook up a real boost gauge and then post your results. :P Link to comment Share on other sites More sharing options...
Volvoson Posted November 22, 2005 Report Share Posted November 22, 2005 White = boost, as long as it's in the white, your car goes WHEEEEEEEEE! But really, get a boost gauge hooked up (use http://volvospeed.com/Mods/boost_gauge.htm for directions) and then we can be much more accurate 9-10psi at WOT is normal for a stock ECU, and 20 in hg (vacuum) is normal if your vacuum lines are in good shape. Link to comment Share on other sites More sharing options...
PorBleemo Posted November 22, 2005 Report Share Posted November 22, 2005 How much boost should one normally see at about 3k? Link to comment Share on other sites More sharing options...
bus stop Posted November 22, 2005 Report Share Posted November 22, 2005 it depends on how hard you step on the gas :P Link to comment Share on other sites More sharing options...
OzzyR Posted November 22, 2005 Report Share Posted November 22, 2005 it depends on how hard you step on the gas So lets say he steps really hard on the gas... boost at 3000rpm would be?? 10psi I spose... might look at the guage next time :blink: Link to comment Share on other sites More sharing options...
maiku Posted November 22, 2005 Report Share Posted November 22, 2005 probably close to 8-10psifull boost comes on at 4000rpm i think Link to comment Share on other sites More sharing options...
narxs70 Posted November 22, 2005 Report Share Posted November 22, 2005 what brand are you guys using? what will a decent boost guage cost? Link to comment Share on other sites More sharing options...
maiku Posted November 22, 2005 Report Share Posted November 22, 2005 autometer ultralitea good one is aroud 50 bucks Link to comment Share on other sites More sharing options...
dancetheman Posted November 22, 2005 Report Share Posted November 22, 2005 don't 850's boost really low...like a 7 or 8 and then for this guy's T5R hit about 9-10 for a bit?that's what mine was doing Link to comment Share on other sites More sharing options...
yangotang Posted November 22, 2005 Report Share Posted November 22, 2005 don't 850's boost really low...like a 7 or 8 and then for this guy's T5R hit about 9-10 for a bit?that's what mine was doingIf I recall Correctly:850T = ~8psi850(T-5)R = ~10psi Link to comment Share on other sites More sharing options...
Guest Guest Posted November 22, 2005 Report Share Posted November 22, 2005 Um, is it normal that my stock turbo bar goes half way into the white and no higher? I used to go about 3/4ths into it and I am confused why I've lost boost in the past few months. Should I check for a boost leak. Link to comment Share on other sites More sharing options...
maiku Posted November 22, 2005 Report Share Posted November 22, 2005 stock gauge is highly inaccurateget a real gauge and fix those leaks Link to comment Share on other sites More sharing options...
Texas850Turbo Posted November 22, 2005 Report Share Posted November 22, 2005 If I recall Correctly:850T = ~8psi850(T-5)R = ~10psiT5 = 9.6psiT5R = 10.6 psitheoretically... :P Link to comment Share on other sites More sharing options...
Jaxx Posted November 23, 2005 Report Share Posted November 23, 2005 mine will hold 11psi when i romp it from 60... that is, after spiking... Link to comment Share on other sites More sharing options...
