JCviggen Posted November 22, 2005 Report Share Posted November 22, 2005 Yeah its me again - dont need to go to work today- boost gauge arrived- Canon S2 IS within reachYou WILL need Divx 5 coded or higher installed for this...google it if you havent got it yettata-->second gear boostthird gear boost (exciting isnt it)Quite a big boost leak The car had been feeling quite strong lately...so I figured I'd see what it could do. However the colder weather also made my tires lose quite a bit of grip... I did 2 runs and couldnt get it to hook up on either one of them....regardless I improved on my 0-100 mph best by quite a few tenths, it now stands at 12.9s I checked my speedo just last week and at 100 mph its very nearly 100% accurate (unlike at 70)The run...and i managed not to hit the revlimiter before shifting And since the 1 gig memcard was far from full......I thought I'd demonstrate how bad an 850 takes a tight corner...but i had to put the cam so far away its not quite obvious enough Regardless, I thought the car sounded very good! Who said a 15G was a worthless turbo ;) Link to comment Share on other sites More sharing options...
Johann Posted November 22, 2005 Report Share Posted November 22, 2005 Hey look, I found a camera.. :lol: Link to comment Share on other sites More sharing options...
PyROTech Posted November 22, 2005 Report Share Posted November 22, 2005 nice videos, but ya we dont see the last one so well b/c cam is to far away Link to comment Share on other sites More sharing options...
JHEIII874T5M Posted November 22, 2005 Report Share Posted November 22, 2005 good deal man, I see it's running pretty well. :) Link to comment Share on other sites More sharing options...
PyROTech Posted November 23, 2005 Report Share Posted November 23, 2005 out of curiousity, how fast are you guys getting the video downloads?then compare to a speed test for me and post results http://www.speakeasy.net/speedtest/my speed test was:using the chicago zoneDownload Speed: 18454 kbps (2306.8 KB/sec transfer rate)Upload Speed: 9159 kbps (1144.9 KB/sec transfer rate)for seattleDownload Speed: 5468 kbps (683.5 KB/sec transfer rate)Upload Speed: 5296 kbps (662 KB/sec transfer rate)major difference from location, im located in ontario canada Link to comment Share on other sites More sharing options...
javadoc Posted November 23, 2005 Report Share Posted November 23, 2005 out of curiousity, how fast are you guys getting the video downloads?I'm getting about 1mbit, but the connection at work isn't all that fast.What the heck is w/that boost drop in your 'vac leak' video?!? I don't have sound here, so I couldn't tell what the motor was doing. Link to comment Share on other sites More sharing options...
turbor850 Posted November 23, 2005 Report Share Posted November 23, 2005 excellent videos if I do say so myself ! ! ! ! small boost fade makes me cry Link to comment Share on other sites More sharing options...
R4Life Posted November 23, 2005 Report Share Posted November 23, 2005 Wowzers. Link to comment Share on other sites More sharing options...
Volvoson Posted November 23, 2005 Report Share Posted November 23, 2005 Videos don't work for me :( Link to comment Share on other sites More sharing options...
JCviggen Posted November 23, 2005 Author Report Share Posted November 23, 2005 What the heck is w/that boost drop in your 'vac leak' video?!? I don't have sound here, so I couldn't tell what the motor was doing.The line to the boost gauge popped off the T piece...creating a huge vac/boost leak '95 R .... do you have divx 5 or higher installed? Link to comment Share on other sites More sharing options...
Volvoson Posted November 23, 2005 Report Share Posted November 23, 2005 The line to the boost gauge popped off the T piece...creating a huge vac/boost leak '95 R .... do you have divx 5 or higher installed?Yes, but I can't even download them :( Link to comment Share on other sites More sharing options...
JCviggen Posted November 23, 2005 Author Report Share Posted November 23, 2005 Yes, but I can't even download them works fine here...!tell me if this works, alternative link , and a second vid Link to comment Share on other sites More sharing options...
Volvoson Posted November 23, 2005 Report Share Posted November 23, 2005 works fine here...!tell me if this works, alternative link , and a second vidThose 2 worked and look/sounded great, but the other 3 links in the first post don't work But, off to bed I go, no worries Jan :) Link to comment Share on other sites More sharing options...
PyROTech Posted November 23, 2005 Report Share Posted November 23, 2005 Those 2 worked and look/sounded great, but the other 3 links in the first post don't work But, off to bed I go, no worries Jan i wonder if your isp or work has a block list with those ips.i want to figure out why it doesnt work for you. ill check the error logs if you can pm me your ip from which you tried to download them from. Link to comment Share on other sites More sharing options...
