Guest ncst8wuf Posted November 22, 2005 Report Share Posted November 22, 2005 I've pulled a P1171. Searching the posts and the conversion chart, it could be anything from a vacuum leak to the Mass Air sensor. Someone also suggested the O2 sensor.My symptoms are as follows:-The CEL has been triggering on and off for the past few days.-I made a 400 mile trip without the light on, the following day the light was on. I made some short drives and the next day the light was off for another 300 mile drive.-Once again the light came on the following day.-The car is not running great, but not rough-just slightly noisier than usual under acceleration.-Highway mileage seems fine, around town seems to be suffering.Should I pay a shop to use a reader that will give me a Volvo specific code, and would that point me closer to the problem?Thanks for any help,Joel Link to comment Share on other sites More sharing options...
MrWinkey Posted November 22, 2005 Report Share Posted November 22, 2005 If you register you will get a better response? But usually a 1171 is a vacuum leak somewhere ;) Link to comment Share on other sites More sharing options...
ncst8wuf Posted November 23, 2005 Report Share Posted November 23, 2005 I have just registered. Link to comment Share on other sites More sharing options...
starfish Posted November 23, 2005 Report Share Posted November 23, 2005 A P1171 is equates to a Volvo ECM-261A Long term fuel trim upper limit. Check for a vacuum leak. The MAF meter could also be the problem, but a bad O2.... I doubt it. Link to comment Share on other sites More sharing options...
ncst8wuf Posted November 23, 2005 Report Share Posted November 23, 2005 Thanks for the info. Would any area be more prone to a vacuum leak than another. I will start to look there.Do I need to check the exhaust also?Once again, thanks,Joel Link to comment Share on other sites More sharing options...
starfish Posted November 23, 2005 Report Share Posted November 23, 2005 Click on the Repairs/Maitenance tab and scroll down to "Engine Vacuum Leaks". Check out the top picture of the vacuum elbow on the intake manifold. It's probably the most common area for a leak to occur. Link to comment Share on other sites More sharing options...
