V Tuning 850 Posted November 30, 2005 Report Share Posted November 30, 2005 So I started my car tonite, and the LOW COOLANT light came on. A minute later it went off. So I went to Advanced Auto Parts and we both discovered that the coolant tank was empty, I mean completely.So I got some Prestone I think it was 50/50 stuff, cause on the tank it says use a 50/50 mix, and filled it up.Seems to be running fine now, no noticable difference though when it was dry.However I feel there is a leak. Should I have the stealership and or another shop look into this?As I don't have the time to look and figure out how to fix it myself. Link to comment Share on other sites More sharing options...
yangotang Posted November 30, 2005 Report Share Posted November 30, 2005 So I started my car tonite, and the LOW COOLANT light came on. A minute later it went off. So I went to Advanced Auto Parts and we both discovered that the coolant tank was empty, I mean completely.So I got some Prestone I think it was 50/50 stuff, cause on the tank it says use a 50/50 mix, and filled it up.Seems to be running fine now, no noticable difference though when it was dry.However I feel there is a leak. Should I have the stealership and or another shop look into this?As I don't have the time to look and figure out how to fix it myself.Yeah. No coolant = car burn up.The dealership will probably pressure-test it and see if there are any leaks. Link to comment Share on other sites More sharing options...
the underlørd Posted November 30, 2005 Report Share Posted November 30, 2005 dude, you gotsta get that scoped out asap rob. Link to comment Share on other sites More sharing options...
V Tuning 850 Posted November 30, 2005 Author Report Share Posted November 30, 2005 dude, you gotsta get that scoped out asap rob.It will have to wait two weeks, so I can be at home to do it.Plans for home...1. Get coolant tank checked for leaks.2. Get an oil change.3. Go to Cindy Rowe for glass repair. Link to comment Share on other sites More sharing options...
JoshV70 Posted December 1, 2005 Report Share Posted December 1, 2005 My coolant bottle used to leak like crazy (out of the top). I replaced the caps with other caps, and it didn't do anything. I finally replaced the coolant bottle, and it solved all my problems. No more low coolant, and no more leaking. Link to comment Share on other sites More sharing options...
V Tuning 850 Posted December 1, 2005 Author Report Share Posted December 1, 2005 My coolant bottle used to leak like crazy (out of the top). I replaced the caps with other caps, and it didn't do anything. I finally replaced the coolant bottle, and it solved all my problems. No more low coolant, and no more leaking.Yeah this is the first time it has happened to me since I had the car.Dad thinks it might have just evaporated. However I think it would take longer then this for it to all just evaporate.I am going to have it looked at when I go home for break. Link to comment Share on other sites More sharing options...
