FINN Posted May 14, 2004 Report Share Posted May 14, 2004 Well since i cant figure out why my right side speakers are out, im going to fix that my way. I am going to put in my old pioneer hu and run all new speaker wire to all of the speakers. Its the only fix that i can think of.How should i go about splitting the wires so that every speaker gets enough resistance and not too much for the headunit. Like for example powering the front door and front dash. Rear door and rear deck?? Link to comment Share on other sites More sharing options...
Jamaica2G Posted May 14, 2004 Report Share Posted May 14, 2004 Lemme tell you something... I was talking such rubbish of replacing the wires for my doors just so that I could get the best clarity, but getting the wires to get from the main car chassis to across to the door is a real BIATCH. I ended up just splicing everything from behind the head unit. I ran RCA's to the amp, then the 4 chans to the cross overs, then from the crossovers I ran them to the wiring kit that I bought from best buy. If you still decide to completely re-wire the door, good luck my friend. TAKE PICTURES of all connectors etc. Rewiring to the rear deck will be the easiest by far. I would say you should just install the HU and put on the wiring kit and hope that that resolves the problem.Adrian Link to comment Share on other sites More sharing options...
Jamaica2G Posted May 14, 2004 Report Share Posted May 14, 2004 My mind is still churning on this one. Did you ever have an accident on the right side of the car near the door terminal. Maybe a wire is pinched? Are both front and back doors not working on the right side? Try just installing the head unit first and check the doors again - my fingers are crossed for you.If you really have to rewire, you'll see the pain-in-the-jerk terminals that volvo left there - just for you Tell us what happens.Adrian Link to comment Share on other sites More sharing options...
850 Stylzz Posted May 14, 2004 Report Share Posted May 14, 2004 Are these stock speakers or aftermarket? I jsut went though a similar dilemma. Decided to re-wire the fronts and rears, but left the doors alone. they do indeed look to ba a pita to rewire. The front doors seem possible, but good luch on those rears.But seriously, how you wire is going to depend a lot on what speakers you havy. Your HU will NOT support a 2 ohm load. Link to comment Share on other sites More sharing options...
FINN Posted May 14, 2004 Author Report Share Posted May 14, 2004 hmmmm........my whole right side is out. They stopped working when i first took apart the dash so maybe something happened to the stock amp? Link to comment Share on other sites More sharing options...
